General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
fuse block upgrade
Old Aug 26, 2013 | 07:39 PM
KBar's Avatar
fuse block upgrade
I'm wanting to upgrade my 27yr old fuse block and and main wires under the hood.Since I've swapped the bat and air box I want to clean up under the hood. I'd like to go with a sealed waterproof fuse block. The only ones I'm finding are 30amp max and they only hold 5 fuses. Can anyone steer me in the correct location.
Old Aug 26, 2013 | 08:27 PM
dropzone's Avatar
Fossilized
Check out blue sea fuse boxes.
They are available in multiple sizes
http://www.bluesea.com/
Old Aug 26, 2013 | 09:34 PM
RSR's Avatar
RSR
Blue Sea X2. You don't need the ones w/ the negative bus btw. The factory is probably more waterproof than these are but if you want just one line to feed it, this is the best option I'm aware of/could find. I have a 6 slot one I'm putting under the hood.
Hella makes some, but they are all fed by multiple lines insofar as I'm aware.
theking11863
Mar 19, 2016 09:36 PM
garagespace
Oct 11, 2015 10:59 AM
rondogracing
Engine Swaps
16
Aug 24, 2015 03:02 AM
94ofCanada
Aug 14, 2015 06:37 AM
rushw
Jul 18, 2015 01:46 PM
