General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Opening Circuit Relay
Old Jan 20, 2013 | 02:44 PM
bolard's Avatar
What exactly does the opening circuit relay do or control ?
Old Jan 20, 2013 | 03:28 PM
MudHippy's Avatar
The Circuit Opening Relay controls the power to the fuel pump. Which is why it's sometimes refered to as the Fuel Pump Relay.
http://personal.utulsa.edu/~nathan-b...96circuito.pdf
Old Jan 21, 2013 | 07:49 AM
bolard's Avatar
Thanks Mudhippy for the reply, my fuel pumps operating fine so I can eliminate that relay as the problem, Thanks........
Old Jan 21, 2013 | 07:56 AM
RAD4Runner's Avatar
What's the problem?
Old Jan 21, 2013 | 08:42 AM
bolard's Avatar
Hey RAD 4Runner,I went to start my Runner and heard a clicking coming from my EFI relay, Found the 15 map EFI fuse next to it blown, swapped it & just turned the ING to the on pos and it blew agian, Cked the obvious wiring & found no problems that I could see, used my meter to ck countinuity on that fuse block & it sounded a dead short, Just trying to figure out were to start, Wiring issues scare the $&@! out of me...
Old Jan 21, 2013 | 09:59 AM
4Crawler's Avatar
Common cause of EFI fuse blowing is an O2 sensor wire that has fallen onto the exhaust melting the insulation and causing a short, either to the exhaust (ground) or the two heater wires for the sensor touching each other.
Old Jan 21, 2013 | 10:58 AM
bolard's Avatar
4Crawler, Thank you for the advice, that seems to be the common issue being said , I plan on diveing into it this week, figure I might as well look into a small oil leak etc. etc. while I'm at it. Thanks agian.....
moparbay
Mar 10, 2023 03:50 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
runnermedic
13
Sep 21, 2015 05:20 PM
EatChipsNow
Sep 9, 2015 01:25 AM
May-39
Sep 6, 2015 01:05 PM
