General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
No fuel/oil/tach after 22re swap
Old 04-15-2013, 10:03 AM
AR52's Avatar
Just finished swapping an 85 22re into my 84. Engine is running and driving strong iv just got a few electrical issues I can't figure out. Oil pressure, fuel level and tach are not working, and my heater fan only goes on 1 speed. Is it possible I'm missing a ground somewhere under the dash?
I pulled the engine, harness, has tank etc from the 85 and everything was working in that truck
Old 04-15-2013, 03:06 PM
SoCal4Running's Avatar
Check "Eng" fuse in drivers side kick panel... If ya got one.
Old 04-16-2013, 07:46 AM
AR52's Avatar
Power coming in and out through the eng fuse, also checked charge fuse. Possible common wire between these gauges that has shorted? Seems odd that a few gauges work though. I'm not the best at electrical...
Old 04-16-2013, 02:52 PM
AR52's Avatar
I have no power running through the yellow/red wire to the tank, before I rip apart my wiring to trace where the power is lost, just want to confirm this wire should have power with ignition on?
mskalmus
05-28-2017 07:51 AM
coleypull15
11-03-2015 07:41 AM
steve miller
10-10-2015 01:40 AM
deepmarsh
08-06-2015 03:44 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: No fuel/oil/tach after 22re swap
