General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Volume air flow and no spark
Old Apr 21, 2013 | 12:44 PM
wyoyodder's Avatar
Hi all, still working on my project truck and still having no success. It is still a 1990 3.0 v6 4x4 and I still dont have any spark. Have tested retested and re-re tested everything under the hood and it all checks out good except just found that the VAF does not check out to specs. My question is can a bad VAF cause a no spark situation. We have tested everything else with the multimeter and it all tests good just the VAF, and as this is my first toyota and I am still in the learning phase I was hoping that someone might know if this is possible. Thanks in advance.
Old Apr 22, 2013 | 01:26 PM
wyoming9's Avatar
Red face
Do you mean the AFM??
I would have to sit down and check but I would think it could cause your issue.
Old Apr 22, 2013 | 03:27 PM
wyoyodder's Avatar
Thanks for all the help with this project, it is possible that I may have got the wrong name but the "VAF" is the air flow sensor on the air box if I am not wrong. That is the part that tested bad. Again thank you.
Old Apr 22, 2013 | 03:36 PM
thekeith86's Avatar
That won't cause no spark to my knowledge. That measures air density and helps measures air/fuel ratio I believe. It will fire with a bad one but run like crap. Start from the plugs and work backwards. Test plugs in a different motor if you have to. There is even a nifty little test light they make specially for the plug boots real cheap. Then test coil packs with volt meter.
Old Apr 28, 2013 | 04:42 AM
wyoyodder's Avatar
Thanks for your reply. I wish it was that easy, I have tested that and everything else down the line from there. So far this is the only part that is bad and I have heard that if it shorts out it could cause that. As it is quite an expensive part I would like to find out for sure, I still need to replace the bad one and if it fixes the problem I will let you all know. Thanks again for all the replies
Old Dec 16, 2013 | 04:02 PM
Gevo's Avatar
Wyoyodder. Can you please respond and post the solution to your problem? I seem to be in the same situation as you are at this point. I put all of my engien back together after a rebuild and.. no spark. I've checked everything, and everything seems to be within spec except the VAFM. I am getting one wrong reading, a 0 ohms between Es and Vb, it's supposed to be between 200 and 400 ohms.
Blamalam
Mar 12, 2022 07:34 AM
Doug4320
Mar 24, 2018 10:11 PM
RatOmeter
Oct 22, 2015 03:17 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
bighaydn
Aug 4, 2015 07:17 PM
