General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Turn signal plug adapters
Old Jan 15, 2013 | 08:43 PM
4runnerJC's Avatar
I just bought a pair of front turn signal light for my 90 4 runner, but the plugs do not match up, the description said they would fit but they do not. I can post pics later but at the moment I'm at work. Do they make adapters? Or do I just by a different set?
Old Jan 15, 2013 | 08:57 PM
Discombobulated's Avatar
Pics, part numbers would help the cause, and yes if cutting or mods are needed I would get what fits no sense in having a headache over something so simple......
Old Jan 15, 2013 | 11:41 PM
wyoming9's Avatar
Red face
If you can`t get the right lights it is a simple matter :jessica: to splice in the correct plugs from your old turn signals .
Just solder and heat shrink your good to go.
As of late I am soldering then using dielectric grease cover that with electrical tape then heat shrink .
To early to tell but it should keep out the salt and water in the winter.
Just what is wrong with your old ones??
Old Jan 16, 2013 | 12:52 AM
4runnerJC's Avatar
I'm missing the driver side one.
These are what they sent me.
Old Jan 16, 2013 | 12:54 AM
4runnerJC's Avatar
This is what I need
Old Jan 16, 2013 | 12:55 AM
4runnerJC's Avatar
Originally Posted by 4runnerJC
This is what I need
It was only $12 for the new lights, just was wondering how i could make them work.
Old Jan 16, 2013 | 12:58 AM
4runnerJC's Avatar
I guess I can get some small female plugs and go directly to the prongs on the lights, or just get the correct lights.
Old Jan 16, 2013 | 10:58 PM
wyoming9's Avatar
Red face
I have connected the pig tails from LED lights using small flat pins to plug into our sockets .
After soldering and protecting the pins and then taping and heat shrinking the whole connection.
Yes a pain to take apart but to me better then getting salt and moisture in there causing things to just corrode away .
MO transplant
Apr 23, 2023 11:58 AM
Jun 1, 2021 01:51 PM
msane99
Jul 17, 2015 10:13 AM
smiley52
Jul 11, 2015 05:16 AM
crashburnoveride
Jul 10, 2015 06:39 AM
