General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
87 4runner electrical fuel injection problem
Old Mar 23, 2013 | 10:46 AM
Vega2837's Avatar
My truck has been off the road for over 2months I cant figure out whats wrong with it. ive replaced multiple sensors including maf, throttle sensor, air valve, coil with the igniter, and ive checked multiple relays. i am at the point where i dont know what to do. Ive taken it to 3 ''Mechanics" and one can even tell me whats wrong.
Old Mar 23, 2013 | 10:50 AM
RAD4Runner's Avatar
Hi Vega2837, first you gotta tell us what's wrong. What is your truck not doing?
A problem well-stated is a problem half-solved.
-RAD
Old Mar 23, 2013 | 12:06 PM
wyoming9's Avatar
Red face
Pretty simple I get this alot!!
It is broke.
How did this start or did you buy it in this condition??
Have you done a 3.4 swap??
Because the 87 only came with the 22R series engines.
And the had a AFM.
Not a whole lot of sensors would keep that engine from running either
Old Mar 23, 2013 | 12:19 PM
wyoming9's Avatar
Red face
I would have to guess your injectors are not opening because for some reason they are not getting the signal.
Bad ground
open harness someplace Hacked wiring!!
The magic smoke has left the ECU to join Elvis
Then again maybe the gas tank is empty
If you changed the coil and igniter your trying to fix a no spark condition what about the wires and plugs any or all could cause a no spark condition
Maybe you just have that effect on mechanics I know i do They just get all glassy eyed and mumble about harmonic balance and Karma catching up with them.
gillesdetrail
Nov 19, 2019 12:56 PM
stagger_lee
Mar 29, 2016 06:27 PM
noahstancik
Jul 10, 2015 11:18 AM
bigblue82
10
Jul 6, 2015 08:27 AM
bobbybouche
Jun 18, 2015 10:22 AM
