'86 4Runner high beams not working
When you push forward to go to high beam it goes dark, but you can pull back like to flash your high beams and they work? Relay or is it in the combo switch on the steering column?
I would say that your hi-beam contacts are shot in the combo switch. You can take the switch apart and clean them up, but it won't get you very far. An aftermarket replacement is probably your best bet. You can get one from a junk yard, but you really don't know what you are getting nor how long it will last.
Cesarl74
Apr 23, 2016 06:07 PM
saphirekosmos
Jun 22, 2015 10:26 AM
LSUMatt1514
Jun 26, 2002 05:03 AM
