General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
93 P/U Weird Electrical Issue
Old Feb 10, 2013 | 06:22 AM
tyedye28304's Avatar
I got a 3.0 5spd 4x4 @ 167,000. Had it about a year and a half now. Previous owner had CB equipment installed. After the altenator died last summer, I went through and removed all the loose wiring. About a month ago, the warning lights on the dash stopped working (Oil, Seatbelt, Door?, Low Volt etc.) Only the E-brake light comes on (and sometimes pops on when it's not engaged). Sometimes the low volt light will come on but will go out if I tap the cover over the fuse box (not synced with E-brake light randomness).
Anyways, went to go replace the all fuses and check for loose wiring around the fuse box last week. While pulling fuses, two of the terminals pulled out with them, but I think it might be those feed line clips you sandwich between the fuse to hook up something else, not sure. Just put them back around the new fuse and out it back in. Everything else looked fine.
Now yesterday coming home, It was early dusk and I switched on my headlights and the power seemed to die. Turned off and the RPM's came back. Radio would shut off then turn back on for a second then repeat. Went to drop off some equipment at my fathers house and the the truck wouldn't start after turning it off. Clicking from the starter and wouldn't take a jump.
Anybody got any ideas about whats gone wrong. Did I screw up the fuse box by pulling those two terminals? If it's the alternator again, then there some other problem. Any help please?
coryc85
Sep 9, 2015 06:24 AM
yourrealdad
Jul 21, 2015 11:13 AM
icentropy
Jul 14, 2015 10:23 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
Poncho0206
Jul 10, 2015 06:21 PM
