- 1985 resto/ big mod
- Sealant/RTV on Intake Manifold Gasket?
- 1984 NEKBONE Resto
- 3.4 swap into 1985 pickup
- 1984 SR5, 4x4, Extra Cab, 5 Speed, Sunroof Restoration
- 1984 4Runner asleep since 2006
- 1984 4runner build
- 85 XtraCab Hard Fuel Lines
- 84-88 Truck Xtra Cab back glass rubber gasket
- Relatively new clutch slipping
- New fuel lines with new tank?
- 1967 Stout body swap
- 1984 Phoenix RV conversion to flatbed
- I hit a wall carburetor 22r 85 pickup/and AC
- 84 Toyota pickup misfire all cylinders.
- My Rusty '84
- Vertex performance chip
- Window not lining up
- Thoughts on performance
- ‘85 Ivan Stewart restoration
- EFI copper crush washers
- How hard is it and how much does it cost to go from a 4.10 gear ratio to a 5.29 gear
- Light Duty Daily Driver 1985 Toyota Pickup
- OME 2" Part Numbers
- How to replace/fix wiring from ignition coil to distributer?
- Won't start
- CreeperSleeper's '85 Xtra-cab
- 1985 - 1989 Body Swap
- 84 rust bucket and 85 SR5 basket case
- 1986 T4R rebuild
- TenCrawler's 1984 Ranch Truck Restoration
- My 84 pickup ground up
- 4.1 differential gears from '85 Pickup
- 1985 4Runner
- My 85 4runner build, project Orange Saphhire
- Pair of 85 4Runners
- 85 2wd 1uzfe pickup
- Ian's 1984 4runner Build Thread
- 85 reg cab
- My Grandpa's 1985 22RE
- Stranded1980's 1985 Ext Cab 4x4 SR5 & 1985 Ext Cab 2wd Turbo SR5
- 1985 XtraCab Build
- Supercharged 1985 Toyota Pickup Trail Rig Build
- 63 chevies laying flat
- 85TRD4Runner's build up
- 1985 Back to the Future Build
- Using a 4 runner to make a 4 door short bed truck?
- Jzoomers 84 5spd long bed build thread (caution slow progress ahead)
- Engine Replacement 85 4runner
- My 85 pickup
- 1984 pickup to 1995 4 runner rear end extended micro motor home build
- 85 wheeler/daily project messy clean up
- 84 Extended Cab 3rz swap
- 85 runner - 5.3 and BJ60's - build thread
- 85 Yota Build
- My 85 SR5 build up
- Kidzilla7x 85 Extended Cab (Just another Build)
- 85 4Runner *Slow Build Up*
- OME ARb Lift for 1985 4runner. Stock frame pins and do I need sleeves?
- 1985 4x4 build up 328xxx miles!
- xJRich25's 85 Ext. Cab Build
- Sayota's 85 Build Up
- 4.3l exhaust swap help
- 84 Extra Cab build
- Chrishf12 85 4runner Build Thread
- 85 xtra cab Pickup
- Gonna finally work on my truck
- 84 4x4 Chinook -yea...another one
- 1985 22re longbed overland outback dreams
- The chode
- 1984' 1uz 5speed 4Runner fiberglass build up
- Toystory "tale of a yota"
- Joe.lit's 84 ish build up
- Priest's 4runner, thoughts?
- 1984 extra cab build up
- small block 350 yota
- 84 pickup 350 swap
- 85 Xtra Cab 4x4 - Retired & Restored trail rig
- 1985 toyota extra cab restoration
- ZeeGee's 1984 Pickup Build w/ videos
- thefishguy77's The Car Seat Crawler
- MrX's 1984 build up
- My 1985 4Runner
- Plainview's '84 SR5 Pickup Driver Project
- my 85' runner build "The Streak"
- 1985 Toyota SingleCab, EFI
- Technical_Driver's Mint 85 SR5 pickup w/57k miles
- the lazy mans 1985 4runner
- 84 4x4 lwb I'm in love
- Julia Lives
- My new '85 toy
- Yota on 46's
- 84 sr5 pickup reg cab
- 1984 Toyota Pickup 1/2 Ton Deluxe - Regular Cab Long Bed 4WD
- SeattleCobra 85 4x4 Pickup 22R Build-Up Thread
- 1984 Toyota Pickup 4x4
- chosenchange 1985 pickup build
- IJCapp 1985 X-Cab
- Toyota 2wd Body Lift
- 85 ex cab slow build
- Chevota Reincarnated
- 85 4Runner - Piggy
- 1985 4wd xtra cab newbie mods and fixes
- nvwiggins 85 5.0 T4R HO
- Mtnloki's 85 runner project
- Ricky239's 85 and 88 Build Thread
- 1984 sr5 4runner
- 1985 4runner sr5. gold/white original rare paint.
- Mikes 85 Toyota 4Runner SR5
- Hello, World! -- Dorj's 1984 Single Cab
- GRoot85's 4Runner Build-Up Thread
- 1985 xtra cab pickup!
- Caroline: FGZ's '85 4Runner DD project
- 4xFords '85 SR5 4Runner
- 1984 4runner v8 resto ,from Australia
- Hitsua's 1985 Toyota 4runner
- major swap
- Build for a buddy. 2wd SAS 84/1st gen truck
- 84 extra cab pickup 22R buildup
- Yota's 85 (blown 22re auto) longbed single cab build
- Sinners 84 truck build
- SqWADoosh's 1985 Runner Build
- The build section is for BUILD THREADS not TECH QUESTIONS
- 85 reg cab trail truck
- CamTom12's 1985 4Runner Thread
- The FailRated '85 Longbed Build Thread
- Bugs 85 runner rebuild
- Trail-gear Springs??
- We-Va's 85 4Runner Rejuvination
- Restoring the Screen Used 85 SR5 Xtra Cab 4 x 4 From Back to the Future II and III
- 84 Sr5 Crawler
- yotagirl_14 1985 4runner
- FiremanJim's 1985 Toy Build
- 85 4runner
- Kawasakilewis 85 Build up thread
- RdS' Blue '84 4Runner Build-Up Thread
- enelson95's 1987 Toyota Pickup 4x4
- 85 22r to 22rte engine swap
- NIGHTMARE's 85 ex can build
- griesburger's 84 4runner build
- cmpete's 1984 SR5 XtraCab Build-Up Thread
- Jaggers 85 yota.
- Whirlybird's 1984 4Runner SR5 Build Up Thread
- 1984 Find and Build Up
- DMs 85 -its just about to begin
- My 1985 4Runner Budget project
- NWTI's 85 4runner build up.
- 1985 4runner Build
- 1984 long bed single cab
- 1985 Toyota 4runner 22re automatic "the rotten apple" build-up
- 1985 22rec sr5 toyota truck
- 85 4R Front Seat Options
- 2TR-Fe
- V8yotabox's 84' Flatbed
- egesledder's 85 "linked 'n boosted" build
- On Board Air for 85 pickup planning
- 85 Toyota SR5 (NEW) Owner
- 84 toy 4runner
- 1985 Astro truck
- 85sr5excab's 85 sr5 ex cab build
- damoek's 1985 pickup CustomCab build
- Westjohns 85 sr5 xtra cab build
- KentSC's Build 2002 4runner Limited 2wd
- ahatt83 1985 4runner build up thread
- high compression 22r
- ***the volunteer*** 1985 22rec
- Fruitstripe's 1985 4runner build
- 84 yota dude's pickup fix
- JTED's 85 BTTFT Build Up
- Hummer96's 1986 Pickup Build Up Thread
- Grass Roots
- YotaInSC 1984 4unner build-up
- Black_1985_SR5's 85 EX-CAB Build and background story
- Yaoksurewhatever's 85 22r 2wd Pickup Build-up...
- Reciver for hitch in front of 4runner??
- 1985 xtra cab build
- L50 L52 Identification
- Project 1984 4Runner Build
- 4Nmissile's 85 Toyota pickup build up
- HunterRunners 1985 4runner build
- My 85 Extra Cab SR5
- Evan711 1985 toy truck build up
- New guy with 85 4-Runner
- Engine shakes uphill at 40-50mph
- Gizler00's 85 4Runner Build Thread
- '85 Yotas Yota! (Lil Red)
- Kornhusker wizards $250 85 Longbox
- shooter101's 84 Pickup Build
- Wolfe7x First Build *NEED HELP*
- 84 Pickup reg cab
- tranny filler plug for '84 4x4 truck
- bryy's 1985 pickup build,
- Rick's 85 4runner build up
- EmazingOregonYota's 1984 Extended Cab Pickup Buildup
- 1985 toyota pickup reg cab longbed 22re atuomatic
- Chris's 89 4Runner
- 85 Extra Cab Saved from Crusher
- 85 Toyota Sloot!
- Tyler's '84 4runner stocker build
- 302 small block Ford swap anyone?
- BlazeN8s 85 L.A./ 86 L.T. Build-Up Thread
- HilUX 84 Suspension Ride Height 28 inches
- 1985 Toyota Hilux SR5 4x4 NorCal Fun Horse
- leaf spring bushings change
- Stevesk88's '85 SR5 Extra Cab Build
- New member new truck
- 1985 4runner rock crawler build
- 1-ton Dually 4x4 SA build (on the cheap)
- 84 22R runner build
- 85 4runner for the VT woods
- 1984 4runner - build up
- 85 4wd frame repair and powder coat
- 85 4runner build. Tommy in SoCal
- Yodaforce 1985 build up
- AK's 85 pickup
- Jloffermann 84 4runner build up
- Redwire23's 1989 4-runner Build Up
- fyrfytrryn's 1985 Pickup Build-Up Thread
- my 1989 toyota!!!
- RSWORDS 85 Pick-up - Project Southern X-Posure
- Tim Steele's 84 Build up.
- New member (build up thread) any advice welcome
- Cabot's '85 SR5 Extended Cab 4x4 (re)Build
- Dieseldreamer '85 ex cab 22re Build-up thread
- 85 runner buggy
- 1984 toyotar pickup build up
- chrisv's 84 pickup build
- 85 SR5 regular cab "street worthy"
- Thor17's 1985 pickup build-up
- '84 SR5 with OM617
- 85 XCab project
- furlong24's '85 build!
- Sons 85 Toyota build
- Sudstoy's 1984 Pickup Build up thread
- Sam24th's 84 Darkside build
- 1984 Flat Bed Yota Build Up!
- skilled4reel's 85 pickup ext.cab build up thread
- Nothingbetters 85 pickup
- Trekkerpaul 1985 build up
- Live4soccer7's Build / WIP Thread - 84runner
- Cruces NM 85 DLX Build
- toyota v8/fj80 axles/ suzuki
- 85 4runner Whitewater Assault Vehicle Build Up
- fullwidthyotaon40s 1985 4runner Restoration
- Possum`s 85 build
- My 85' ext cab build
- GEOz2k7 84 4runner sr5 build up thread
- 3YLSYKR'S '85 4Runner Toy Build
- xJRich5's '84 Yota Build
