New guy with 85 4-Runner
Old Feb 17, 2013 | 11:55 PM
jon6.0's Avatar
I just traded one of my dirtbikes for a 1985 4-Runner yesterday. A 2000 KTM 640 Adventure R for 4-Runner with a 22RE, LC Engineering stage 2 ported head, Downey mid-range cam, header and a Electromotive TEC-GT stand alone engine management system that has distributorless ignition and coil packs. You can plug in your laptop and change the tune or make whatever changes you want. Supposed to be a Marlin Crawler lift, but I think it may be All-Pro? It's very softly sprung and dives pretty good under braking. Bilstein shocks. I'll have to measure the body length of them. It does have hi-steer also. The clutch doesn't start engaging until darn near the top of the pedal travel. So I expect that's on its way out. The A/C compressor kicks on, but the blower motor doesn't run. 4.88 gears and a locker in the back. I want to add some 1.5"-2.0" wheel spacers as it is still really narrow and pretty dang tall for just 33x12.50's. I also may do 35's when the 33's wear out.
The bike I traded(blue and orange one):
Old Feb 18, 2013 | 07:26 AM
Gizler00's Avatar
Awesome Deal you got their!!! I love the red with the Black top. That distrubutor less setup is pretty cool.
Old Feb 18, 2013 | 08:37 AM
dropzone's Avatar
Fossilized
Watch out for shackle inversion with that 90* f/r shackle angle.
Hopefully it is new springs waiting to settle..
*edit: I would also inspect that front spring mount, it looks to be mounted at a slight downward angle (might be the pic, the one above the bike pic), should be flat and add a brace so you don't crack the frame
Old Feb 18, 2013 | 04:47 PM
jon6.0's Avatar
I think the front mount is just a weird pic angle. It looks okay in person.
What is the optimal shackle angle? I might need to get the shackle mounting done over maybe?
I snapped some pics:
The other rear shackle is like this one. Why wouldn't they just use the mount already there?
Old Feb 18, 2013 | 10:31 PM
jon6.0's Avatar
Just talked to the previous owner. The springs have been on there for a few thousand miles. Looks like they are as settled as they will get.
Old Feb 24, 2013 | 01:06 PM
51willysjeep's Avatar
You could always pull one of the leafs out of the front packs, and that will bring it down about an inch or so. Mine was up too tall as well once my springs had "settled", and pulling a single leaf fixed the problem. The addition of front spacers will also enable you to get a little more steering as well as a little wider stance. Truck looks great so far..! Subscribed.
Old Feb 24, 2013 | 01:15 PM
jon6.0's Avatar
One of the middle leafs? I just put new wheels on that are 1" less backspacing, so that got me a little extra width. I still think I'm going to do 1.5" spacers also. How do you like the KM2's? That's what I think I'm going to get when my BFG AT's wear out. I also discoverd I have quick release hinges on the doors. I can get them off in about 30 seconds. So as soon as I get some Wet Okole seat covers the doors and top are coming off. In a box of parts that came with the truck was another Lockrite. It just needs new springs and pins. That will be going in the front diff.
Level 8 Tracker from Discount Tire. 15x8 -30 offset
Old Feb 24, 2013 | 01:49 PM
Yes, I pulled the second one down from the main leaf out, and so far its worked great, and it also softened the ride a bit as well which was a plus. Your new wheels look great and that extra backspacing will help out alot. I really love the KM2's, they have great road manners, contour well over obstacles when aired down, and they also clean out pretty good as well. I haven't had any problems with them and would recommend them to anyone.
Old Feb 24, 2013 | 01:59 PM
jon6.0's Avatar
So the third one from the top if the top is #1?
Old Feb 24, 2013 | 02:06 PM
Correct
Old Feb 24, 2013 | 02:08 PM
jon6.0's Avatar
Correct
Did you pull any out of the rear?
Old Feb 24, 2013 | 03:00 PM
My rear pack was a custom mix of toyota and chevy leafs I kept playing around with, until I had the correct ride height I wanted. I also have a custom set of solid steel 1" lift blocks with machined in center pins ( which I didn't really want to run at first) but they have worked out great so far. Eventually I am going to build a custom pair of 65" leafs and cut the stock rear mounts off and move them forward for better articulation.
Old Feb 24, 2013 | 03:03 PM
jon6.0's Avatar
Cool. Thanks.
Old Mar 14, 2013 | 07:19 PM
kornhuskerwizard's Avatar
i like the runner better than the bike!!nice!!
Old Mar 14, 2013 | 09:09 PM
Roark's Avatar
That Runner is up there, man! If you plan on doing any serious crawling or off roading in general, I'd try to cut down 2-3 inches instead of just 1. I've seen and heard of too many top heavy trucks rolling from such a high stance.
Still looks awesome, though!
Old Mar 17, 2013 | 08:49 AM
Gizler00's Avatar
Ill gladly take those springs off your hands, if you want to lower your rig. haha. I Personally think it looks great the way it is.
polo451
13
Nov 20, 2016 07:49 PM
daddio
Jul 18, 2015 10:20 AM
cgilley
Jul 15, 2015 03:32 AM
timmJ
Jul 7, 2015 02:01 PM
wilbertd
Jul 6, 2015 07:39 AM
