View Full Version : All Other Toyota Swaps
- 1UZ non-vvti, A343F into '91 Land Cruiser FJ80 w HF2A
- 22re to 3rz air intake guide
- 1st gen Rav4 engine swap
- 1UZ Swap Guide - 2nd Gen 4Runner
- 1UZ Swap Finished, Low Idle/Vac
- 2ND Gen 4runner with a subaru brat body
- 1UZ to r150 maiting, clutch setup question.
- Subaru BRAT body on a 2nd gen 4Runner Frame. Wiring questions
- completed 2tr-fe swap into a 1988 toyota pickup.
- 1gz Fe swap questions
- 2nd Gen 4Runner 1UZ Swap Wiring (94 LS400)
- 3RZ swap with IFS? Oil pan source?
- Need some help with older Toy clutch choice.
- 2016 Hybrid Lexus CT 200h into my 86 with a 22r
- 1988 4x4 22R drivetrain swap to automatic
- Help me find perfect swap ...please !
- 89 3vze in a 92 truck.
- My 1UZ 87 4Runner swap info
- Stock 1993 pickup 2jzge swap
- Time for a new 20/22R rocker cam?
- 1980 pickup cab/bed into 1994 chassis and running gear?
- 85 second gen Pickup build with Supercharged 1UZ
- Feeler thread ??
- Completed 2TR-FE in 87 22re 4runner
- Do I need a new transmission?
- Preparing To Swap a 1UZFE into my '93 Xtra Cab
- What Parts Are Needed For A 1UZ Auto Trans 4 X 4 Conversion?
- 22r to 1uz swap
- Toyota FJ 40 Land Cruiser V8 conversion
- 2002 camry 2.4 to 3.0 swap
- A couple 3RZ questions
- 2nd gen 22re into a 3rd gen pickup truck
- Transmission swap
- 1jz gtte into 95 4runner
- ECU from a 94 Crown transmission
- Should I do a V8 transfer or supercharger?
- Land cruiser 85, Swap 2jz, se puede montar?
- 1994 2jzge Block and 2jzge vvti block
- 22RE motor replacement 93 Toy Truck
- chukarhunt's 1uz swap, need some input
- 3S-FE swap?
- 1uzfe in 91 4runner
- Trans swap question
- 86 2wd
- For those who have completed a 1UZ swap. Share your thoughts about your swap
- 84 22R to 3RZ fuel line advice
- 2013 Rock warrior wheels on a 2016?
- 1UZ > 94: Yes, looking for opinions, guidance.
- Anyone know..?
- 22RE to 7MGE swap radiator fitment HELP!
- toyota 2tc to 22r swap
- lexus 3VZE FE V6 swap into 3.0 3VZE 4 runner
- Toyota RV. Will a 1994 3.0 V6 engine replace a 1990 3.0 V6?
- 89 toyota 350 vortec
- Waterproofing the 1UZ
- 03 toyota echo engine swap, will not turn over!...
- 1uz swap write up. 92 lexus ls400 1uz into 94 4runner(3.0/r150f/4x4)
- 3S-GTE in 93 4Runner
- Geemans 1UZ 4Runner
- 1uz wiring swap confirmation
- 1uzfe swap NEED HELP!!!!
- 86 pickup custom cab 2uzfe v8 swap
- wanting to do 1uzfe swap into toyota pickup
- Time For A V8
- North West Toys specializes in 1UZ swap parts and other off road accessories
- 7MGTE into '86 2wd!
- starting the wiring of my 1uzfe swap. what I am not understanding?
- 1uzfe swap into 92 toyota RV 2wd
- t100 2jzgte vvti swap
- 1989 3vz3 --> 7mgte SWAP 4x4 SR5 Xcab
- 88 to 89 22re engine swap
- 1UZ VVTI/A650E into 94 T100 4x4
- 2uz combustion chamber size comparing to 1uz?
- 3.4 or 1UZ clearance needed for crossover in 85 truck
- 1993 SR5 1UZ Build
- 1UZFE into 1980 Pickup
- 5MGE motor mount location
- 5MGE swap wiring
- 2jzgte
- 7mgte swap drivability questions
- Anyone know where RMA went
- 1uz-ef electrical diagram
- 2wd 1uzfe swap drive line question
- Replacement radiator options after 3rz swap
- A/C compressors and swaps
- Looking for a shop in Denver area.
- 88 4Runner 7MGE swap, need help
- 2rz wiring
- 1985 IFS pickup with 7mge wont start
- 85 toyota cab swap
- 1986 4runner with 7mge wont start anymore
- 2jzgte + 86 4runner
- I have a cracked head, rebuild/replace?
- Looking for recipient of my turbo 6M-GE
- NEED HELP!! 22RE conversion
- Ect ecu question!!!
- 1UZ-FE into a Toyota T100 Auto 3.4
- 3vze to 5mge swap with auto trans help
- 22R to 22RET Conversion
- auto to 5 speed in a 4runner? easy or worth it?
- wiring diagram
- 1UZ Flywheel Options Please!!!!!
- 85Toymans 1994 4Runner 1UZ Build
- 1UZ vs 2/3RZ size
- 1uzfe in toyota pickup
- Reliable Importer for 2JZ-GTE ?!
- 1990 ls400 1uzfe swap wiring pinout 90-95 4runner
- 1uz swap time !!!
- Somethin' 'bout a 1994 Truck 1UZ Swap
- 1uzfe transmission options
- Live4soccer7's 84runner 1UZ Swap
- E-locker swap
- 1UZ to 86 T4R 22re Dual Case 4x4
- Are you content with your 1UZ swaps...still?
- drum to disc brake conversion 1984 4runner
- auto to manual hub swap
- 1JZ GTE VVT-i into 22R 84 Runner
- 1jz gte vvti into 84 runner clutch ?
- 93 4runner, 3.0L to 3.4L help.
- 2002 2uz swap into a 1999 Tacoma
- 7MGTE Truck!
- 81 22r put in 87 sr5
- 350 or???
- Transmission and Transfer HELP!
- 3vze Measurements
- 1UZFE Mileage?
- Wire harness schematic for LS400 needed
- 5mge swap 90 4x4 v6
- 1uzfe speedo wiring
- 1985 to 1989?
- E-locker power source?
- 20r/22r hybrid
- 1uzfe ks racing bellhousing
- 1uzfe oil filter mount
- 22re swap and build question.
- Can't wait for BOOST! egesledder's 7mgte swap
- 97 5spd 4runner to auto
- 1uzfe to R150 clutch question
- 1UZ-FE FAQ ,Swap Guide For The 84-89 4runner and Pickup
- GM small cap HEI to 22re
- 4.0 v6 5speed swap
- 1UZFE Swap humble beginings.
- 7mgte swap w A340F tranny
- Lexus Swapped 90-95 Truck/4Runner Dash Pics
- potential engine swaps 94 pickup
- 3RZ-5VZ-1UZ Bling badges
- 1uz swappers, looking for your opinions.
- 7MGE swap starting issue??
- 7mgte into my mk3 Hilux
- 22re into '54 Willys wagon
- 5mge ignitor wiring issue
- Tach resistor mod
- Ether's 22RE Auto to 22R Manual Swap
- Want to swap my 5vze to a 22re
- 1uzfe Swap In 86 4Runner Questions.
- Tims 1990 4Runner 5-speed 1JZ engine swap guide
- 22rte to 22re in 1987 Turbo 4Runner
- From 3.slow to V8 in my 93 P/U
- 1UZ swappin' my 1999 4RUNNER!!!
- 1983 hilux 3rz swap engine mount issues
- 1uz seal axle options
- 90 4runner LT 2wd 2uz swap questions.
- 1UZFE swap in a 92 xtra cab
- 1uz-fe needs
- Calling all 1uzfe enthusiasts
- 1GGTE Swap into Hilux
- I found a 3rz for CHEAP!!!
- toyota 4.0 swap
- Kalmah's 7M-GTE Swap into 93 Pickup
- 94' Ex. Cab 2UZ Swap
- 1989 Toyota pickup 2jz single turbo swap
- Built 22re turbo Vs. 7mge swap
- need advice on motor choice
- RADesigns '82 2RZ swap to an A340
- i have a wicked wiring issue and i need help
- 3.0L swap to 2.4L
- 2RZ Emblem BLING!
- 7M-GTE swap into 86 pickup 4wd
- 86 and 94 engine swap
- 341e,aw4,340f
- A few 2RZ swap questions.
- Researching 7MGTE swap, would appreciate feedback
- Did I get everthing?
- 98-04 Tacoma 3RZ to 5VZ Swap/Conversion
- '95 3.0 "stand alone" tips requested
- Some 3RZ swap Questions
- 1uzfe
- Almost there..
- 1uzfe swap in my future?
- 86 to 89 engine swap wiring ?
- Camry motor into pickup
- Questions about changing my '86 22RE Turbo EFI to another kind
- radiatior relocation
- Bigtrucknwheels' 90 Pickup 7M-GE Swap
- 7mgte gauge help
- my 22r to 21r-u nightmare
- 1uz - A44xx trany question.
- i need a trans that ll hold at least 400 hp from a 7mgte
- 2nd 1uz swap into a 1988 4Runner
- 3vze vs. 1uzfe
- My 1990 Xcab Lexus V8 swap
- A Few Questions for 3RZ Swappers/Experts..
- 7m swap
- V8 engine swap for CA smog and referee?
- 1UZ-FE swap into a 1990 2dr 4runner
- Tranny swap options for 22RE
- 7mgte motor swap into 80
- 2jz ?'s
- Concerns with a 7mgte swap
- 3.slow to 22re???? yes? no?
- 3RZ Info please
- 3vze to 22r swap
- Beginning my 5VZ swap
- 1UZFE vvti into 2nd Gen 4runner
- New to Yota swaps...
- 93 landcruser prado with 2jzge in it
- 3vz to 22r swap
- 1988 4runner 1uz swap
- 1993 LS400 1UZ-FE wiring diagram
- 89' Yota 1UZ/A341E/VF2A
- so i got a 2.7l tacoma engine and trannie dirt cheap.....
- 4.0 into '94Runner?
- 1UZ-FE Swap 2nd or 3rd Gen 4Runner help
- The 95 4runner 1UZ swap project begins
- 4RunnerGuys 4Runner 1uz swap
- black89t's 7mgte swap
- totaled t
- 3vze to 22re
- 1990 supra powered 4runner good idea or bad
- Problems with an '85 tranny swap from auto to man.
- 1uz-fe into 93 pickup with R150f and IFS
- 1992 Lexus SC V8 - Southern California
- little help on camshaft position for 89 toyota
- 22re to 7mgte in a 94 2wd swap
- engine swap 87 to 92 22re
- 1uz Harness
- 5mge (supra) swap-Tranmission options on 85 Truck
- GTS Engine
- Second Gen 4Runner Transmission Swap.
- 1UZ-FE into 94 4Runner
- Supercharged 1UZ 4runner
- 3.0 V6 problems
- Swapping Engines in 93 Toyota pick up
- 96 2.7 into 86 4runner - wiring help please!
- 1990 Toyota Pickup 1UZ Swap with R150f Tranny
- Supra swap into an 85 4runner
- 7mge wiring
