All Other Toyota Swaps I4, I6, Lexus V8
Help me find perfect swap ...please !
Old Apr 19, 2021 | 07:05 PM
Anubis's Avatar
I have a 1990 v6 4x4 slt extcab automatic and im trying to find a toyota v8 automatic motor and transmission that will fit with little to no tweeking ....want to keep it a toyota ....or its just a yoda body on a different brand truck and im not down with that ...thanks chris
Old Apr 20, 2021 | 10:45 AM
Numbchux's Avatar
Toyota has been making V8 engines since the '60s in various configurations, and AFAIK they've all been done in some fashion.
https://en.wikipedia.org/wiki/List_of_Toyota_engines#V8
Give us some idea of what result you want, how much you want to spend, how much you're willing/able to do yourself.
Old Apr 20, 2021 | 01:42 PM
irab88's Avatar
A 3.4 (5VZ-FE) will basically bolt right up, throw on a supercharger and it'll keep up well enough.
Not sure about any V8's that'll bolt up (otherwise, I might have done that instead).
Old Apr 21, 2021 | 06:35 PM
Anubis's Avatar
Welll hummm?🙄
Looking for a v8 that will have best 4wheel drive thats compatible with the 90 ex cab that will still keep it some what lite and i wont have to do to much tweeking but will do what is nessassary and as of price ..not really wanting to go over 15k if possible.....thanks
Old Apr 21, 2021 | 08:39 PM
moto809's Avatar
5 Year Member
If you want to stay Toyota, a supercharged 5VZ will be the absolute easiest and cheapest swap into your 90 pickup. If you're hell bent on a V8... well there are better engines than Toyota has to offer.
Old Apr 22, 2021 | 04:53 AM
rattlewagon's Avatar
a v8 will take a lot of tweaking. No way around that.
Old Apr 22, 2021 | 08:20 AM
Numbchux's Avatar
I don't know what you define as "much tweeking", or not. I think my 1UZ swap is fitting very nicely, but modifications have been necessary.
Here are the highlights. Most Lexus/Toyota V8 engines are in RWD cars, and most of the 4WD applications have the front diff on the LH side. AFAIK, the only exception is the FJ100 land cruiser, but the rear transfer case output is also offset to the RH side, which is not ideal. So you can't really use any engine/transmission/transfer case assembly from one donor vehicle.
There are options to change that. The T100 case can be adapter to a RWD auto trans pretty easily. Or there are a couple aftermarket adapters to use the old gear-drive tcase (which means you can use aftermarket gears and/or dual cases).
The UZ is the most common family to swap. This was available in 3 different displacements, with aluminum and steel blocks, with and without VVTi. All are a decent option.
http://northwesttoysllc.com/1uz-2/ is probably the most one-stop-shop source for parts to install one. You can buy everything you need from him to make it a bolt-in swap. He can probably do the whole swap for you.
Anubis
Jul 30, 2021 09:18 AM
Anubis
Engine Swaps
Apr 19, 2021 06:27 PM
TheMadScientist
May 1, 2011 03:07 PM
rdrttoy
Engine Swaps
Apr 16, 2009 09:38 AM
Schwartz04
Domestic Swaps
May 12, 2008 04:10 PM
