All Other Toyota Swaps I4, I6, Lexus V8
5mge ignitor wiring issue
Old Mar 27, 2012 | 11:23 AM
1984yotaSR5's Avatar
Okay so I am almost ready to start my truck after doing my swap to the 5mge... but there is one wire that forgot to label coming off the ignitor it is yellow coming out to a single wire green plug and turns to black wire on the other side if anyone could help out it would be appreciated.
Size:  41.4 KB Name:  IMAG0464.jpg
Old Mar 27, 2012 | 04:41 PM
suppra87's Avatar
I'm not positive on this but after reviewing the wiring diagrams for the 85 Supra with the 5M, it appears as though that is the tach signal wire.
EDIT:
Old Mar 27, 2012 | 05:46 PM
i used all the alldata wiring diagrams and the tach signal actually comes off the ignitor as a black wire this comes off the ignitor as a yellow wire then turns to black after the connector. any other possibilities?
Old Mar 28, 2012 | 04:08 AM
suppra87's Avatar
Are you sure this is the ignitor and not the resistor for the injectors? Sorry if that seems like a dumb question as you seem to know your way around wiring diagrams and these components fairly well.
Old Mar 28, 2012 | 06:49 PM
yes it is the ignitor. it just so happens that i mounted the injector resistor next to the coil.
the wires off the ignitor are as follows
Black (Tach)
White & Red (distributor)
Tan (Main Relay)
Yellow (?)
Old Mar 29, 2012 | 07:32 PM
here is a little better photo if anyone has done this swap or has a 5mge it would help a lot if you could pop your hood and check
MO transplant
Apr 23, 2023 11:58 AM
Sleaker
Aug 26, 2020 06:03 AM
raptor510
Feb 17, 2017 07:11 AM
smiley52
Jul 11, 2015 05:16 AM
nick b
Jul 11, 2015 04:38 AM
