All Other Toyota Swaps I4, I6, Lexus V8
341e,aw4,340f
Old Sep 8, 2011 | 10:52 PM
88runnasr5's Avatar
341e,aw4,340f
ALright I know there is a thread somewhere around here that had all my answers, if someone knows the thread, or just wants to give me there answer, that would be appreciated..
I'm going to be doing a 1uz swap in my runner, I'm trying to figure out the transmission delema, I have seen somewhere someone buy a 340f, take the valve body from the 341e and put it into the 340f.. I'm trying to figure out how to make the 341e end with the aw4 tail housing, I plan on running an atlas case and want all the crap to work.. Sorry if this seems like a bunch of babbling idk exactly what I'm talking about..
Old Sep 9, 2011 | 08:09 AM
RMA's Avatar
RMA
Originally Posted by 88runnasr5
I'm trying to figure out how to make the 341e end with the aw4 tail housing.
I dont know what the aw4 tailhousing looks like but its supposed to be like the toyotas ..
check this adapter out .. looks like the one side will fit the lexus a341 the other side is the aw4 , right?
http://cgi.ebay.com/ebaymotors/Jeep-...Q5fAccessories
Old Sep 9, 2011 | 08:10 AM
RMA's Avatar
RMA
are you wanting to go driver or passanger drop.
Old Sep 9, 2011 | 11:16 AM
88runnasr5's Avatar
At the moment I don't really care what side drop that would all be on the atlas I buy..
But I think I'm more comprehensive right now and can actually ask the question..
I have access to all 3 transmissions, I know I could go 341e to inchworms adapter yadda yadda but that's kind of pointless to me, I can get a 340f swap the valve body out of the 341e to keep the firm shift points, and get a adapter from aa to an atlas, or I can take the tailhousing of the aw4, the spline count is the same but the shafts are bigger and has the 6bolt round that I need to keep away from buying any adapters, my main concern is the wiring, I know the computers are picky and like everything hooked up to them, anyone know how I can do said project?
Also rma the aw4 and the a3xx where all made by aisin, there ideally the same casing with slight changes everything can be swapped around..
Old Sep 9, 2011 | 12:49 PM
RMA's Avatar
RMA
if your gonna stay auto , you should try to keep the lexus auto .. the a340f rear extension housing will bolt to the lexus auto then all you need is the aa adapter to the atlas .. no need to open up the trannies and switching valve bodies and much easier to wire up to the ecu.
http://www.advanceadapters.com/products/pn-50-5710/
Old Sep 9, 2011 | 08:17 PM
RMA's Avatar
RMA
tune up 666 .. what did you end up doing for the VSS .. since you need it for the tranny to shift right ..using the a340f 's tail housing then aa adapter you can keep the vss with out modifing anything ..
and wheres the videos man .. havent seen any , hows she doing.
Old Sep 9, 2011 | 08:52 PM
88runnasr5's Avatar
That's what I was wondering myself.. I would go that route but want all electronic crap to work..
Old Sep 11, 2011 | 03:29 PM
RMA's Avatar
RMA
i had to shim the vss also (2mm I think) using the t-100 autos extension tailhousing.. works great .
i have the pieces of shaft i cut on the lexus auto
about 1.198
Old Mar 4, 2012 | 08:15 AM
ridgerunner101's Avatar
I need help with a 98 4runner Limited 4WD with a 340F transmission. It hard shifts from OD to 3rd back and forth several times. With OD off, it shifts fine. ECT Temperature sensor resistance is 700 ohms at operating temp which is a little high. Anyone else had this problem and found a solution. In the process of checking the other sensors first and solenoid resistance.
CGS
Jun 2, 2015 12:35 PM
joe mcg
3.4 Swaps
Nov 1, 2014 03:50 PM
SEAIRESCUE
Sep 28, 2009 03:16 PM
cheap4r
Dec 5, 2008 10:10 AM
