All Other Toyota Swaps I4, I6, Lexus V8
i need a trans that ll hold at least 400 hp from a 7mgte
Old 05-23-2011, 11:55 AM
ffryno13's Avatar
i having a problem trying to find a trans that i can use in my swap. my 7m has 500hp at 37psi + NOS but i dont run NOS and i run my boost around 30psi. the w56 that bolts up wont be able to take that kind of abuse and i cant think of a divorced t case to run on it with the r154 (2wd) trans. i want to use a M/T so i can really use all of the power and i want to keep my 4wd too. HELP!!!
Old 05-24-2011, 12:01 PM
ffryno13's Avatar
nobody? really?
Old 05-24-2011, 01:04 PM
snobdds's Avatar
I guess a better question is why don't you think the W56 will fit your needs? I know of a few people with a 7mgte and a W56 set-up that there running.
Just curious...
Old 05-24-2011, 05:36 PM
91diesel's Avatar
I've talked with guys on here who 'basically' just bolted the transfer case on the back of the R154. Or you could just get an R150f from a V6 truck. From what the guys who did the supra swap said it looks like if you have the 4wd drivetrain from a V6 truck you can bolt that up behind a R154.
Old 05-24-2011, 05:54 PM
ffryno13's Avatar
Just curious...
most of them are running pretty stock motors. and i m kinda rough on my toys along with running all that boost and i dont want to have to replace a trans every time because i shear the input shaft?
Old 05-24-2011, 06:01 PM
ffryno13's Avatar
the r154 is a 2wd trans so not sure how they are bolting it on but im not 100% on if the v6 is a divorced t-case. i have only had 22re s. r150f i wouldnt think woud hold that much torque or HP cuz both the 22ret and v6 are only putting out about 150-160 hp.
Old 05-25-2011, 06:36 AM
91diesel's Avatar
the R150f and the R154 is the same internal transmission other than the gear ratios and the transfer case so it's really just as strong. The guys said they bolted up the transfer case on the R154 by unbolting the tailshaft and replacing the pieces with the tailhousing and what not from the R150f.
Old 05-25-2011, 03:45 PM
ffryno13's Avatar
@tuneup: i just hate going back and replacing and spending money on things when i could "measure twice and cut once". thanks for the link man.
@91diesel: thanks, do happen know which bellhousing it is that mates to the 150f and the 7m, or do i just use the bell form my 154 and put it on the 150f
Old 05-26-2011, 05:00 AM
91diesel's Avatar
All 'R' series transmissions are the same case. So a R154 bellhousing is needed to mount a R150f transmission behind a supra motor. This is also why you apparently (I haven't done it myself so.....but I researched it for my diesel) can unbolt the tailhousing off of a 154 and bolt up the shifter/4wd parts off of an 150. Although you'll probably just want to use the 150 due to the lower first gear. The 154 has a taller overdrive gear which may be a consideration for you, that's what I was going after .75 vs a .85.
Old 05-26-2011, 08:42 AM
ffryno13's Avatar
Originally Posted by TUNE_UP666
I kinda looked into the getreg trans for you (the 2jzgte trans) and it can be bolted to the the 7m but I dont think anyone had put a tcase behind it
it would have to be a divorced t-case to run behind it if your talking about the 6spd supra trans. otherwise i dont know which trans your talking about? i cant remember what other M/T trannys they put behind the 2j
im really hoping to to have the taller OD cuz i do drive ALOT of highway and this will be my DD.
Old 06-01-2011, 08:04 PM
ffryno13's Avatar
so i was doing some thinking today and how cool it would be if i had regular duty auto but be able to switch to manny when i want to roast some rubber. any suggestions or should i say options?
Williamemslie
14
10-05-2015 09:28 AM
JHalcyonM
09-14-2015 01:10 AM
an1mal_69
09-08-2015 09:40 AM
viesail
09-05-2015 04:23 AM
eggens
09-05-2015 12:16 AM
Quick Reply: i need a trans that ll hold at least 400 hp from a 7mgte
