All Other Toyota Swaps I4, I6, Lexus V8
3.0L swap to 2.4L
Old Sep 27, 2011 | 11:00 AM
Stryker727's Avatar
3.0L swap to 2.4L
I have a 93 4runner with 3vz 3.0L v6 and want to swap to the 22re 2.4L.
I was wondering if first will the 3.0L trans bolt into the 2.4L
and if the motor mounts will be there same? Since they did have both the 2.4 and 3.0L in that year
I know i will have to get a ECU and wirring harnnes for the swap.
Old Sep 27, 2011 | 11:34 AM
MaK92-4RnR's Avatar
the motor mounts and transmission will not bolt up. you'll need a R150F to w56 bellhousing conversion. i think marlin crawler sells one. and you'll need to custom fab your own motor mounts.
just drop a 3.4 in. everything bolts up.
Old Sep 27, 2011 | 03:39 PM
Stryker727's Avatar
If I was to get the motor mounts for the 22re wouldnt that work and if i was to get the motor and trans wuth it. shouldnt it bolt up the body aswell since they were made with the 3L and 2.4L
Old Sep 27, 2011 | 03:43 PM
SCToy's Avatar
3.4l swap, same or better mileage, better power, bolts up mostly, you'll have more trouble with a 22re swap. Better to just sell the truck and buy one with a 22re if you're heart is set on it.
mskalmus
May 28, 2017 07:51 AM
defrag4
Jul 31, 2015 10:50 AM
JefferDean
Jul 31, 2015 10:39 AM
hexrain
Jul 12, 2015 01:13 PM
Coreyr384
Jul 10, 2015 11:13 AM
