All Other Toyota Swaps I4, I6, Lexus V8
radiatior relocation
Old Jun 14, 2011 | 06:06 AM
farmboy191's Avatar
So I want your guys opinion, I'm putting a 7mgte in my 92 extra cab and i am goin to mount a gigantic racing radiator on my roll bar.
Now my question is what should i run it back there with? I want something that is hard like PVC and an aftermarket pump to keep it goin.
Last edited by waskillywabbit; Jun 14, 2011 at 06:14 AM. Reason: Inappropriate Language
Old Jun 14, 2011 | 06:10 AM
blake.nemitz's Avatar
i believe you can fit it all under the hood and not be so hack with it. google supra runner.
Old Jun 14, 2011 | 11:34 AM
toyminator2000's Avatar
I've seen 1.5" exhaust tubing work. Buy a mandrel bend kit and some straight pipe from Jegs or Summit and weld it up. I've seen 1uz swaps that had rear mounted radiators and the stock water pump was able to handle the load.
Old Jun 14, 2011 | 11:42 AM
RBX's Avatar
RBX
Copper
Old Jun 14, 2011 | 12:47 PM
xxxtreme22r's Avatar
Galvanized Fence Post.
No really subscribing cus there is a guy in town here running a bed mounted rad in his 350 yota, I'll ask him what he did.
Old Jun 15, 2011 | 09:39 AM
farmboy191's Avatar
I'm running it in the rear because the one I am goin to run wouldn't fit under the hood anyway. My car runs hot and that's moving at 100mph so i figured to be safe just go all out damn thing has been with the stock 3.0 for the last 5years and 400k it finally gave out.
But what i was thinking was PVC because its easy to fabricate and if it breaks its an easy fix
Old Jun 15, 2011 | 09:51 AM
irab88's Avatar
http://www.ppfahome.org/pvc/faqpvc.html
The typical upper limit for continuous use of PVC pipe is 140 F
...which is lower than the 195 degree water that comes out of the rad, not to mention what goes in
sphealy
Sep 3, 2015 07:55 PM
bobpat
Aug 1, 2015 09:25 PM
AkitaDog
Jul 27, 2015 02:38 PM
Bluto
91
Mar 17, 2005 08:33 PM
HuntRunner
Nov 23, 2004 05:55 AM
