Rear Shock Relocation and Xreas?
Old Nov 23, 2004 | 05:35 AM
HuntRunner's Avatar
Not sure I understand the relocation of the rear shocks......Is this something that has to be done? At what lift height is this a must? How do they work?
For those that are using them, do you notice any change in performance on road and off road? How/Where do they install (pics?)?
Old Nov 23, 2004 | 05:55 AM
kickaha's Avatar
Pics can be found here: https://www.yotatech.com/forums/show...6&page=3&pp=25
There's a lot more information in that thread you may be interested in.
For most all suspension lifts (except XREAS), when you lift you also get longer shocks as part of the lift. The reason is that the shocks can only travel so far up or down before they max out. The longer shocks compensate for this. With XREAS, it is technically possible to replace the shocks, but no one makes longer XREAS compatible shocks. You could also technically dump your XREAS system and replace it with a standard system, but that would mean throwing away a pretty decent system for on-road handling.
Relocating the XREAS shocks seems to be a best of all worlds option. You get to keep your XREAS system, you get to keep your lift, and the XREAS shocks won't be maxed out as easily as without the relocation.
All that being said, there are certainly a lot of people running Daystar and Revtek spacer lifts without the relocation mounts and I have yet to hear of a problem. Personally though, I would consider this as cheap insurance for your XREAS system.
Yotadawgjr
10
Aug 23, 2015 10:51 AM
terminator
Jul 27, 2015 07:13 PM
Massmayhem247
Jul 18, 2015 05:46 AM
icentropy
Jul 14, 2015 10:23 AM
akaphilly
Jul 9, 2015 02:34 PM
