All Other Toyota Swaps I4, I6, Lexus V8
1uzfe transmission options
Old Jun 16, 2013 | 10:35 AM
jmswltn's Avatar
over the past year i have gathered a small collection of yota parts and resources so i have a lot of options but am looking to spend as little as i have to and would like to keep auto,4wd, and my factory cluster as the ls400 cluster i have doesnt light up and the fuel gauge is out.
my base is a 91 4R and a complete 90 LS400 (minus driver side windows)
I am looking for the most cost effective method to swap in the 1uz
I have:
the factory auto lexus trans which shifts well.
a340h shifted well when removed but has cut harnesses now
g52 with transfer never ran it but looked fine when i had it apart
w56 with transfer drives ok but 3rd gear seems iffy on downshifting
w55 runs good but 2wd
w46 runs good but 4 spd and short final drive
r150 with transfer never ran but loos to have been rebuilt and is clean
As most everyone knows the lexus trans are all setup for IRS using a 3 bolt flange with vibration damper.
I assume with a little bit of time with a caliper, and some cad software i could have a 3 to 4 bolt adapter made for around $75
I could just bolt a drive shaft to this that would be great but i wouldn't have a speed/odometer as mine is cable driven, nor would i have 4wd
The Inchworm adapter to take the lex trans to 4cyl transfer case
was my primary option but i have recently heard they are no longer supporting the 21 spline input shaft coupler:
Originally Posted by tyes
the 21x23 coupler were also not in production anymore and only the 23x23. i made a mistake and order the 23x23 and called back to exchange. base on their website, u have the option of both. he wanted me to return the kit and pay for restocking fee if i didnt want the setup.. i end up buying a 23 spline input gear from TG and installed it. Inchworm website is all wrong. false advertisement if u ask me...
If this is the case than cost would be
adapter $700+40 for shipping
23 spline input shaft $180+~20 shipping
and having to tear apart my transfer case
or use the case behind my r150 which is 23 spline but not sure if they bolt up the same
my next option is the thai company KsRacing who sells trans swap kits which are higher up in the price range but are complete:
http://www.ebay.com/sch/i.html?_odkw...using&_sacat=0
problems with this:
its kind of pricey $1100-$1280 depending on the clutch
it looks as if the slave cylinder is in line with the exhaust on the right side.. i would think that this would melt the seals in the slave. i guess header wrap would stop this.
no speed sensor for lexus ecu ive heard conflicting info on if this is needed or not.
3rd option
take input section from the lexus trans and install in a340h. cebby started going for this but ended up going with an a340f i believe
anyone can chime in on this as i can not find any solid information on this.
upside: the cost is practically free
downside:
a340h is a power and mpg sucker.
ecu will not communicate correctly with this trans
so with what i have, whats my best option here?
oh an everything is for sale: toledo,ohio make offer...
Old Jun 17, 2013 | 03:48 PM
serg4x4's Avatar
Originally Posted by jmswltn
3rd option
downside:
1UZ+A342+TRANSFER ASSY LEXUS 450
Old Jun 17, 2013 | 04:02 PM
serg4x4's Avatar
5VZ+A342E+TRANSFER ASSY LEXUS 450
Old Jun 17, 2013 | 04:09 PM
serg4x4's Avatar
1UZ + A342 + TRANSFER ASSY 4Runner 185 multimod
Old Jun 17, 2013 | 04:22 PM
serg4x4's Avatar
1UZ+A343+TRANSFER ASSY LEXUS LX 450
Old Jun 17, 2013 | 07:45 PM
jmswltn's Avatar
serg, nice rig but that may be a little out of my scope... although it looks as if the kid did all the work lol.
we cant exactly pick up a lex trans and case from the parts yards around my way,I cant even find toyota trucks or suv
Old Jun 18, 2013 | 12:53 AM
serg4x4's Avatar
Old Jun 18, 2013 | 06:29 AM
toyminator2000's Avatar
The easiest option is to find a T-100 auto transmission and transfer case from a 3.4 liter equipped truck(95-97). It has the A340F transmission and the transfer case drop is where you need it to be. You will only actually use the output portion of the tranny so if the rest of it is no good or has high miles it's ok. You have to remove the 3 bolt flange from the lexus tranny and unbolt the tail housing. You will need to cut the output shaft at the correct length but then you can just bolt up the t-100 output with the transfer case right to it. you may also want to use the t-100 tranny fluid pan because it holds at least a quart more than the Lexus pan does.
Old Jun 18, 2013 | 07:17 PM
jmswltn's Avatar
I should rename this to serg's build thread... great info though.
toyminator thanks for the tip, I will keep my eye out for the 340f is it only those specific years t100?
do you know why cebby didnt stick with the 340h?
Old Jun 19, 2013 | 05:13 AM
Pretty sure those were the only years. It had to have the 5vz engine. The earlier ones had the 3vz 3.0 and the same A340h that you already have. 5vz equipped 4runners and tacomas had the transfer case drop on the wrong side.
Not quite sure why Cebby didn't keep the A340H but he would have had issues with it communicating with the Lexus ECM properly. The input shaft on the oil pump was shorter too but I think he was able to swap it with the Lexus transmission. The A340H has it's transfer case married to the transmission and they shared fluid, not very desirable and difficult to upgrade later.
Old Jun 19, 2013 | 07:17 PM
tyes's Avatar
this would be your best option considering inchworms incomplete kit. this will be a little work but on the positive note, you wont have to deal with driveshaft mod and cutting your floor board. if i didnt live in cali and didnt have to smog, then i would have went with a 5spd and ksracing would have gotten my business...
Old Jun 19, 2013 | 08:34 PM
jmswltn's Avatar
i have been looking around the local yards for the 95-97 t100 trans. i found 1 (only) that was $550 for the trans and 4 something for the case. At that I may as well go for the kit (IW), i already have a 2 inch shorter auto drive shaft, and 2 4cyl cases.
could go all pre-runner $200 or less to combine shafts..
just really hate to go thru the effort to swap in the uz and not be 4wd.
this 22r/tbi is ok but poor power and 16 mpg just sucks
Old Jun 20, 2013 | 04:12 AM
car-part.com list a bunch of them in the Ohio area. Some even had close to 300k miles, which would be perfect for you since you don't actually need the tranny to work.
Old Jun 20, 2013 | 07:58 PM
jmswltn's Avatar
there is one on there for $400 128 miles from me i wonder if they would just sell me the back half?
I'm calling tomorrow to find out if the case included as they dont specify.
Old Jun 27, 2013 | 05:27 AM
jmswltn's Avatar
what is it with parts yards every place around me wants 750+ for a used sometimes very used 340f.
in my owners manual it shows the 22re with automatic 4wd had the manual transfer case is this the 340f?
Old Jun 27, 2013 | 11:55 AM
jmswltn's Avatar
found a 22re auto 4x4 trans that i have confirmed that is a manually shifted tcase.
will i still be able to use the tail section like with the t100 trans or are the inputs different?
Old Jun 28, 2013 | 08:47 PM
jmswltn's Avatar
well after driving 100 miles to get the 4cyl trans. I did a little more research and found that the outputs are said to be different from the 5vz models. I have not confirmed this yet with my own eyes. if so I will have to swap the shaft also or swap the 341 input section to the 340f
Old Jun 28, 2013 | 09:36 PM
serg4x4's Avatar
YOKE, TRANSMISSION SLEEVE 33399-60040
Old Jul 1, 2013 | 05:16 AM
jmswltn's Avatar
so i believe serg is saying they are all the same on the inside.
but i dont understand the part number provided it leads to a land cruiser transfer adapter. does that one take the lex tranny to the 4cyl case?
Все выходы такое же количество сплайн, но разной длины
то, что транспортные средства являются те 3 передачи от
извините мой перевод я использую Google Translate.
каковы различные муфты от?
Old Jul 1, 2013 | 12:53 PM
serg4x4's Avatar
yes
exception -
A343 lexus LX 450 - FZ- 98, A343 lexus LX470 - 2UZ - 98-02 for the American and European market of sale
entrance leanly
30-80LE 4runner 130 3VZE hidrauics transfer case
30-43LE 4runner 130 2LTE mehanical transfer case
30-40LE 4runner 185 1KZTE
33399-60040 ctandard coupling of Toyota
http://www.toyodiy.com/parts/xref?s=...on&mJ=on&mG=on
http://www.land-cruiser.ru/index.php...ic=150515&st=0
