PDA
View Full Version : Solid Axle Swaps, All Years
Pages : [1] 2 3 4
  1. Snapped stud SAS spacer.
  2. 70 Series LC front Diff in FJ80 Housing
  3. Clunking Noise in 4WD SAS
  4. 93 pickup SAS and rear chevy springs
  5. 3vze/5vze oil pan swap necessary for SAS?
  6. 92 SAS defective steering arms?
  7. Should I buy these axles?
  8. want asking for Roof Rack Setup on 2010 Toyota Tacoma
  9. DANA 80 TO TOYOTA ADAPTER (dxf download file)
  10. Nissan pathfinder rear axle in a 94 pickup?
  11. Someone buy my rig
  12. Cs009r old man emu springs for RUF spring alternative?
  13. What leaf springs for my 91' SAS 4runner? (wheeling/camping/road use)
  14. 1994 Toyota SR5 SAS
  15. Frenched front hanger
  16. Front Driveshaft Options
  17. 1991 pu sas
  18. 6 shooter knuckles on IFS hubs
  19. 1986 Toyota Pickup up truck 4x4 front axle solid swap.
  20. Is this axle housing usable?
  21. Identify part
  22. Land cruiser Prado 150 sas conversion
  23. Front driveshaft angle
  24. Swap Dually 5 lug to 6 lug Motorhome axle
  25. Newbie here. Solid axle spartan locker installation?
  26. Newbie here. Solid axle spartan locker installation?
  27. Leaf spring help!
  28. Toyota steering box leak near input shaft at small ball/check valve?
  29. Right place? 1985 front axle
  30. Need help identifying this third member
  31. Help me identify my axles with certainty please!!!!
  32. Front axle housing damage
  33. Differential swap
  34. Dodge 1500 Axle For Tundra SAS
  35. Need some help sas and 4wd conversation on a 1977 pick up
  36. ‘88 SAS Driveshaft Research
  37. Trailgear front hanger kit bushing do not fit 84-88 Ruf springs
  38. 1993 axle swap
  39. SASing a RHD, any major differences compared to the LHD?
  40. 2001 Double cab Tacoma Dana 44 swap/Chevy 63
  41. Driving with no front 3rd member
  42. Thinking of doing a SAS swap on my 94 runner need info!
  43. IFS Steering Box Location for 88 SAS
  44. steering swap
  45. Hello
  46. 99 Toyota Tacoma SR5 V6 3.4L DUALLY SWAP HELP
  47. '69 fj40 retro to centered e-locker diff
  48. 7.5 8.0 pinion flange
  49. 1979 Toyota and collected parts
  50. 1979 Toyota full width swap write-up.
  51. E-Locker on front and rear axles
  52. Rear locking diff in 92 4runner
  53. Differential swap
  54. TG 4" - leaning to passenger side
  55. rear axle hub 80 series landcruiser
  56. SAS 4th gen 4runner
  57. 3 link solid axle swap
  58. axle swap
  59. SAS 88 pickup
  60. Tacoma axle swap question.
  61. dana 60 to 01 tacoma question?
  62. Found me a axle for my sas
  63. 2006 tundra sas
  64. Axle/Brake Caliper ID??
  65. SAS under spring
  66. Axle housing?
  67. SAS with All-pro 4" lift springs, frame tube location
  68. I am wanting to do a SAS on my 88 pickup, what would be some axles that would be best
  69. Suspension squeaking! Please help
  70. which Toyota axlw for a 1932 chevrolet coupe
  71. Rav4 Axle swap and lift?
  72. Help identifying Aisin hubs
  73. Rear diff in SFA?
  74. 1986 Toyota pickup sas
  75. Wandering steering sas
  76. 3rd Gen pickup sas and build
  77. Shackle angle help
  78. 3rd Gen 4Runner SAS
  79. Chevy63 leaf spring swap
  80. Caliper grinding on rotor
  81. Power steering pump failure after SAS
  82. SAS 2x4 89 -95 & mercedes 617 swap
  83. What FJ axle do I have?
  84. 1986 4Runner SAS Build Up!
  85. Steer axle for rear on 1987 4Runner?
  86. 1993 sas
  87. Which front solid axle to use? 66 Landcriuser or
  88. Solid axle swap issues
  89. 1997 Toyota 100 with a Dayna 33 must go 8183991494
  90. 92 sas swap begins
  91. Dana Performance for LandCruiser
  92. 85 Axle housing
  93. 2wd 87 pickup sas
  94. need help identifying this axle on my 92
  95. Why a toyota sas?
  96. 87 pickup sas opinions please.
  97. Trail gear heavy duty drive line kit
  98. 85 toyota pickup 2wd to 4wd
  99. Chevy axles
  100. Midnight 92 SAS
  101. Sas as a daily driver
  102. 91 4runner SAS
  103. SAS Swap
  104. 93 PU sas, question on donor axle type
  105. SAS swap
  106. ne here..85 axle swap
  107. bushings or joints on front 3 link?
  108. 91 sas yota
  109. SAS dana 60
  110. front spring issue
  111. Wheel/Tire Setup on 1990 Pickup with 85 Solid Axle SAS
  112. Spring under ??
  113. Which U Bolt Sizes Do I Need
  114. Lockers and solid front axle
  115. Detroit Locker.... HELP!!!!!!
  116. Newb looking to do an ENTIRE drivetrain conversion on 2gen 4Runner
  117. Second Ge Tacoma SAS
  118. Flying91's IFS height SAS on 30's
  119. Skyjacker springs for sas
  120. steering for straigh axle
  121. 1987 Toyota 4Runner SAS
  122. SAS question
  123. IFS Eliminator for 88 Xtra cab w/ matching rear?
  124. Rear end for an 89 pickup
  125. Trail Gear 3'' or 4'' SAS kit picture request
  126. Need Help With Vented Rotor Swap On 80 Front Axle!!
  127. 1992 Sas
  128. Parking brake after SAS
  129. Frame swap help
  130. SAS 1988 toy 4x4
  131. high steer
  132. 1985 Toyota Sunrader
  133. 92 pickup sas leaf spring question
  134. 1993 pickup
  135. 89 2wd sas
  136. What's going on here?, pics inside
  137. Gears for a 2lt on 35's
  138. SAS help
  139. stock sas?
  140. I need SAS swap information
  141. SAS help
  142. HELP! Shackle Angle on Trail Gear 1993 SAS
  143. 89' hilux 2WD
  144. Should I SAS
  145. 86 pickup 4bt cummins waggy d44 axles
  146. HELP! Wheel Bearing Preload Issue!
  147. can anyone id this front axle?
  148. 4runner SAS - Lowest Possible Lift
  149. 1 ton full floater rear swap
  150. 87 xtracab SAS
  151. New all pro 3 link sas kits for later model tacoma 4 runner and fj cruiser
  152. 86 shortbed SAS questions
  153. SAS options
  154. SAS front propeller-driveshaft need help
  155. Full width swap.
  156. SAS positives/negatives
  157. Thirds swappable
  158. First SAS on 93 pickup...(questions)
  159. hanging leaf springs
  160. yota project. could use advice
  161. my rehab 99 taco SAS
  162. FJ40 AXLE IN A 1st GEN MINI?
  163. 73 Toyota 2wd SAS
  164. SAS FJ60 with axle housing flip and front shackle for my 2001 Tacoma
  165. Toyota rear in a Mazda
  166. 87 4runner SAS weekend project
  167. SAS costs
  168. Toyota Dually SAS
  169. 1994 4runner low sas
  170. 95 4runner Sas F+R axle relocation questions
  171. Springs and shakles question
  172. 88 solid front axle swap
  173. 95 4runner 87 jeep wagoneer SAS
  174. swapping axles from a 81-84 to 1980
  175. shackle frame tube demensions
  176. Which model? How to ID my axles
  177. Is SAS on a 2wd legal in California?
  178. tg 4" kit
  179. Solid Axle compatibility...Need some help!!!
  180. DD Trail Gear Front 3link
  181. 80 Series axle jig to add leaf spring pads or 3/4 link bracketry
  182. 1986 4runner with sas looking for shocks
  183. 98 T100 Axle Swap Questions?
  184. TG shackles and hanger ?'s
  185. 89 4runner SAS Finally
  186. Aligned SAS and developed Death Wobble
  187. 98 4Runner need advice on lift choice for 85 soild axle swap!
  188. IFS locking hubs bolt on?
  189. 90 reg cab, ideas for the moment
  190. 1989 Single Cab Axle Swap Project "Ol'Grey"
  191. Some questions
  192. 89 Toyota box truck: Questions
  193. mud truck build " axles"
  194. SAS swap rear spring problems
  195. 85 solid axle
  196. 92 pickup SAS help
  197. 99 4 runner
  198. problems with v6 sas?
  199. 1987 4runner.. couple questions
  200. 01 4Runner - SAS - Is my steering too flat?
  201. G282 diff donor for a 88 V6 4runner SAS
  202. CURRENT SAS kit options
  203. Stoner's 92' Pickup sfa
  204. 8 inch differential setup
  205. Scuba's 99 Single Cab SAS.. 5 Years in the Making
  206. 94 4runner, sas, ruf, dana 60, 14 bolt, gm driveline
  207. 3" SAS on 93 Pickup
  208. Help with fj80 coild swap
  209. Relocating mounts
  210. supra LSD longevity
  211. How to remove the stock steering box on my 85'!?
  212. Need manufacturers
  213. 1997 toyota t100 3.4L 4x4 Ext.
  214. 89 4runner SAS too dang high
  215. Mild lift with SAS?
  216. pitman arm option
  217. 8in ring and pinion compatagbility question
  218. shackle question
  219. Need help! 87 sas
  220. 87 pickup sas
  221. 88_Red_Runner's Tired Of IFS...
  222. Front Hanger Placement?
  223. SAS clunk.....clunk.....bang....
  224. TG 27 spline kit missing clips?
  225. Ever swapped a Jeep axle into a 94 pickup?
  226. Please advise! Rear lift suggestions?!
  227. Full width spring hanger?
  228. doing axle swap
  229. Different gearing or drivetrain help
  230. 2wd and turning it into 4wd
  231. Sas Qs
  232. 91' Pickup Low SAS
  233. To SAS on an automatic pickup ?
  234. 94 Shortbed S.A.S. Q/A
  235. SAS with RUF springs 95 4runner
  236. 87 SAS started!
  237. oil pan in a sas
  238. 4 cyl 3rd members for SAS w/ light V8 power???
  239. Help! How to build highsteer crossover steering for SAS
  240. crossover steering tie rod ends
  241. gearing???
  242. Seek"N"Run's Sas / build
  243. Trail Gear SAS Problem
  244. 4 link extension and angles?
  245. 4 Link Heim suggestions
  246. Trail Gear Lift Springs
  247. 86 turbo sas
  248. Any one running the Rock Assault Trunnion Bearing Eliminator Kit?
  249. Land cruiser front axle in 86 4runner
  250. 1980 Front Axle Housing ?
