not sure if this is in the right section. I was wondering if anyone could id this front axle. I can get it for dirt cheap but she doesn't know much about it except that its off a yota. Thanks for any help.
im by no means an expert but it looks like a high pinion diff and the knuckles dont look pickup or 4runner. id guess land cruiser, maybe one of the more experienced guys will kick in some info.
That's a Suzuki samurai axle. Almost made the same mistake earlier this year. You can tell the Toyota solid axles by the gusset that is factory welded on the bottom side. 79-83 is a short gusset and 84-85 gusset goes from third member all the way to the hub
I'll get a better pic of it when I get home...
question now is what's the deal with these auto hubs? Definitely not gonna use them. Thinking about using my ifs hub instead. But I read there isnt a 54mm nut on the end. Maybe I read that wrong.
Close. 83 was first year of gusset, 84 gusset goes to the middle of the spring perch, 85 it goes all the way past the perch.
You can use your IFS hubs, but youll need the conversion gear to get them on the solid axles 30 spline shaft. Not sure on the conversion from auto hubs though.
Heres a good write up on getting rid of the auto hubs.
Close. 83 was first year of gusset, 84 gusset goes to the middle of the spring perch, 85 it goes all the way past the perch. You can use your IFS hubs, but youll need the conversion gear to get them on the solid axles 30 spline shaft. Not sure on the conversion from auto hubs though. Heres a good write up on getting rid of the auto hubs. http://www.4x4wire.com/toyota/tech/autohub/
Are you sure? Because I have two 81s and they both have the short gusset. I know they are original also.
