8in ring and pinion compatagbility question
Old Dec 30, 2013 | 11:24 AM
williamb82's Avatar
This is my first post, hope its a good one for you guys and that you have the answer. I searched this forum, and could not find the info I am looking for. Also, I hope this is the correct sub forum, it seemed to be the best fit for what I am asking.
Long story short, I am wanting to run G series 8in ring and pinion gears in an A series 8in case. I know the ring gear and LSD will fit, as Powertrax lists the same part number LSD for both G series, and A series, both are 10 bolt ring gears, but a different bolt circle. The Powertrax is drilled for both and the carrier bearings mount in both cases. What I am not certain of is if the pinion gear will fit the case. I cant find definitive info on the shaft diameters and lengths, however I have confirmed they are both 27 spline. I "think" they use the same pinion bearings as I have seen diff install kits listed as the same part number for both series of gears, but even if this is true, I still need to know if the lengths are the same.
I want to run a Detroit True Trac lsd, but they do not make one for the A series 8in, only the G series 8in. So since I have to buy new gears anyway, if the G series will fit the case, I will just buy those. And no, I will not just swap the entire axle as I am not running solid axle, and the True Trac LSD will not fit in the G series IRS case, however it should fit the A series case as it is larger.
Thanks for reading and for your help!
Old Dec 30, 2013 | 11:40 AM
JasonYota's Avatar
What kind of vehicle do you have? Do you have a 4 cylinder or v6 3rd? Front or rear axle?
JasonYota's Avatar
Welcome from Alabama
Old Dec 30, 2013 | 11:46 AM
williamb82's Avatar
I have an 84 Toyota Supra, currently with the stock 7.5in IRS diff upgraded with a True Trac LSD for the front of a 89 4runner 7.5in diff with 3.73 gears(Was 4.30 gears stock). Diff I am planning to swap in is from a 92 Lexus SC300, but going to change to 4.30 gears and hopefully a True Trac LSD as i am changing from a 7mgte/r154 combo making a lil over 400rwhp to a 2jzgte/T56 magnum combo that should be ~600rwhp on 93 octane and ~800rwhp on E85..
Will gears from say an 89 4runner 8in rear diff fit in the 98 4runner rear diff?
The SC300/SC400/GS300/GS400/GS430/LS400/Non 6 speed 93-98 Supra all have the same A series 8in ring and pinion as the n96+ A series found in 4runners and other trucks(Though Not the Land Cruiser or Tacoma). They just happen to be IRS instead of solid axle. 200mm 10 bolt ring gears is what I am dealing with.
Edit: Still doing research on Google. The part number for the Pinion gear install kit is the same for both, so at this point I guess all I need to know is if the pinion shaft lengths are the same. If they are, then it'll work.
Old Dec 30, 2013 | 12:03 PM
TOYROX's Avatar
I Have swapped the lsd carrier from a mk3 supra into a v6 4runner housing. And my v6 gear set has been swapped into a 2000 elocker housing. but I am not sure the pinion length on the independant is the same as a solid rear axle. Does this help?
Old Dec 30, 2013 | 12:11 PM
williamb82's Avatar
Independent and solid axle gears are the same. You can use solid axle gears in the IRS case and vice versa. That helps tremendously. Thank you! Looks like all I have to verify now is if the True Trac LSD fits the A series case, which I believe it will. I just haven't gotten a response from Eaton yet with the dimensions.
bigjstang
Jun 2, 2025 03:56 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
oldirtydirt
Feb 23, 2020 09:30 AM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
kirkrunner
Jul 27, 2015 07:59 PM
