Aligned SAS and developed Death Wobble
Old May 27, 2014 | 03:09 PM
Kristo44's Avatar
Was towed out and didnt have issues except tire wear and vague steering. Towed in and have major death wobble. Replaced tie rod ends from Pittman arm to passenger hi-steer arm. Helped a little. Went wheeling and almost dies 5 times on way home. Wheel bearings are good. Trunnion bearings are good. Any ideas? Or just keep chasing parts in front end? Thanks for any help.
Old May 27, 2014 | 07:32 PM
c0ugar69's Avatar
did you check caster angle? i think thats what it is. the trunnions should not be stait up and down but have about 3 degrees back. might check that.
Old May 27, 2014 | 08:09 PM
nothingbetter's Avatar
when you did your sas did you change tires?
my death wobble went away when I had my tires "balanced"...errr...5 lbs of weights on a super swamper.
Old May 29, 2014 | 08:38 AM
osv's Avatar
osv
death wobble is usually caused by tire issues, those joints you replaced, or possibly shackle bushings.
when the sas was done... was the axle rotated? spring perches relocated? was that trunnion angle accounted for?
Old Mar 21, 2015 | 10:56 AM
Kristo44's Avatar
fixed.
It was tires. Thanks for the help.
Old Mar 22, 2015 | 10:11 AM
BigBluePile's Avatar
Lawlz......
ladybugRC
458
Aug 21, 2020 10:41 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
voiddweller
Sep 28, 2015 11:21 PM
Toys4parts
Sep 26, 2015 01:56 PM
Project90
Sep 24, 2015 11:40 PM
