stock sas?
Old Apr 1, 2015 | 08:22 AM
cb'sYOYO's Avatar
stock sas?
Hey guys I'm thinking about buying a 92 2wd that I want to sas I have an 82 with good engine,4spd trans,t case,drive shafts,front and rear end,and springs but the frame is broke in 3 places so my question is what else do I have to have for a sas all the kits I've saw have lift parts I'm just going for a stock ride since I have all theese parts
Old Apr 1, 2015 | 08:49 AM
JasonYota's Avatar
Research the blue 2wd pickup SAS build over on Pirate. 2wds frames are different than the regular 4wds.
Old Apr 1, 2015 | 09:53 AM
dropzone's Avatar
Fossilized
2wd frames are nice because they don't put the front springe hanger up so far
You will need a front spring hanger and a tube fit for the rear front spring mount (goes through the frame )
https://www.trail-gear.com/TG/Front_...x#.VRwwicvn9oM
Peobably going to need to swap to a 4wd oil pan too
maybe a cross member too for the t/c
Old Apr 1, 2015 | 04:25 PM
cb'sYOYO's Avatar
Thanks for the tip Jasonyota according to that thread sasing a 2wd is almost easier because the 2wd frame is almost the same as the old 4x4 frames
Old Apr 1, 2015 | 04:28 PM
cb'sYOYO's Avatar
What ever truck I do the sas on is going to get the whole 4x4 running gear out of the 82 so hopefully no clearance issues with the oil pan
Old Apr 1, 2015 | 04:34 PM
cb'sYOYO's Avatar
Thanks drop zone that's a damn good price on that kit everything I've looked at has been 1500 plus next question is with the reared will the 4x4 springs line up with the existing mounts or do I get to play with the torch some more in the post JasonYota referred me to the guy used the 2wd springs and rear end
Old Apr 1, 2015 | 04:41 PM
dropzone's Avatar
Fossilized
Yes, your existing rear springs should work, spring over with new ubolts, think u bolt flip kit
Oil pan clearance can be an issue. I have an engine out of a 2WD ready to go in my truck that i will need to swap to a 4wd oil pan because of the front axlw
Old Apr 1, 2015 | 05:29 PM
cb'sYOYO's Avatar
decision time
Ok so my plan was to buy a 92 2wd I found on cl for 900 with a blown head gasket and auto trans good deal or no? If I get it I was gonna pull engine and trans out of my 90 2wd and put in it since it's got a good body you could throw a cat through the floor of my 90 and not hit a thing but any way keep 92 as dd and sas the 90 I personally think 900 is kinda steep for a vehicle woth a blown head gasket possible warped head does have water in the oil guys says runs good so I can only imagine what the bottom end looks like if he's been driving it I think would be fair deal for 650-700 what do you guys think?
Old Apr 1, 2015 | 05:34 PM
JasonYota's Avatar
Don't forget the added cost of getting a 4wd trans and transfer case. And a stock 2wd rear axle will be 5 lug instead of the 4wds 6 lug bolt pattern.
Old Apr 1, 2015 | 05:36 PM
cb'sYOYO's Avatar
I have a complete 82 4x4 with a frame that's broke in 3 places
Old Apr 1, 2015 | 05:40 PM
JasonYota's Avatar
Post some pics of the one your looking to buy. Hard to say what it's worth without pics and more info about it
Old Apr 1, 2015 | 06:12 PM
cb'sYOYO's Avatar
http://lexington.craigslist.org/cto/4947398523.html sorry best I could do as far as pics
Flying91
45
Apr 11, 2024 04:39 PM
A2theK
Sep 30, 2016 12:50 PM
I8URSVT
Sep 3, 2015 11:42 AM
jake_v
Aug 27, 2015 03:18 AM
87hoerunner
Aug 24, 2015 09:49 AM
