supra LSD longevity
Old Feb 6, 2014 | 05:23 AM
stevenf's Avatar
supra LSD longevity
Ive read there fairly common lsd diffs for strength and availability. Considering putting one up front when I sas. Checking to see if anyone here has experience running them with large tires. Also, do the 8" lsd's fit the 4cyl truck axles?
Old Feb 7, 2014 | 05:51 AM
stevenf's Avatar
Anyone?
Old Feb 7, 2014 | 07:10 PM
kornhuskerwizard's Avatar
Yes they do. Have any info on your rig or what your sas'ing?? be more helpful if you describe what you have and what your working with.
Old Feb 7, 2014 | 08:09 PM
stevenf's Avatar
Arent all 8" 4cylinder truck carriers the same, regardless front or rear or year? Its going in an 86 pickup with a sas from a 81 pickup.
Old Feb 10, 2014 | 04:44 PM
88_Red_Runner's Avatar
The Supra LSD will not work in a SAS. It will only work in an IFS front for a 2nd or 3rd gen p/u or 1st or 2nd gen 4Runner.
Old Feb 10, 2014 | 06:35 PM
donomite49's Avatar
early supra has 7.5" ring and pinion, fits front ifs axle,later models have 8.0" ring and pinion fits rear axle and front straight axle.
for HP lsd rebuild kits http://www.weirperformance.com/
gear info http://home.4x4wire.com/erik/diffs/
Old Feb 10, 2014 | 06:44 PM
donomite49's Avatar
to answer your question about the supra lsd diff strength, they can support mega HP with a modified supra engine.
look up a supra website they can go as high as 1000 to 1400 HP iirc.
love to have a 2jzgte, but how can you support it with a running gear in a 4wd application?
Old Feb 11, 2014 | 03:31 AM
R.DesJardin's Avatar
Yes they work in truck diffs.
Well this guys shows how to. I've read write ups on using it many times.
http://www.gearinstalls.com/supralsd2.htm
Were you talking about the whole differential housing maybe? The Supras are not of a drop out design, they are designed like a D44 more or less.
Old Feb 12, 2014 | 05:21 PM
My bad I thought you were talking about the whole 3rd member. I understand now that your talking about the limited slip carrier.
Old Mar 25, 2014 | 06:24 PM
TOYROX's Avatar
Hey Steve, I ran a supra LSD on 35" tires. It didnt work for me. It performed no better than an open dif.
Old Mar 25, 2014 | 07:10 PM
nothingbetter's Avatar
Lsd won't get you what you need for traction off road. This is of course assuming you want it for off road purposes. What you need offroad is power to all the tires all the time. a lsd doesn't accomplish that. Save some pennies and buy a selectable locker.
This video does a good explanation. Despite the accent and boring vehicles and simple terrain it gets the point across. The green "prada" has a lsd. Silver has factory electronic traction control, and white has arbs.
As for strength, guys run 5-600 hp through these rear ends roasting off tires and racing.
justdifferentials
14
Jun 11, 2017 08:36 PM
primordialbeast117
Dec 19, 2015 12:23 PM
toyotasaurus
Sep 24, 2015 03:30 PM
justdifferentials
Sep 5, 2015 06:52 PM
jaretstuff
Aug 4, 2015 02:08 PM
