89' hilux 2WD
Old Mar 12, 2015 | 09:49 PM
89hilux1's Avatar
89' hilux 2WD
i have everything to do the swap. just need to what to do to make it right and be ride height of 83' 4x4 and im swapping trans also
Old Mar 21, 2015 | 03:50 PM
thefishguy77's Avatar
There is tons of information on this on here over at marlin crawler and on pirate 4x4 use caution on pirate if you ask this question you will at best get ignored and more than likely get made fun of till you don't come back. Use google to search what you want to do. Put yotatech in with your search. Then repeat with marlin crawler then pirate. You should read till your eyes bleed. Then a little more. You also need to be more detailed in you question. Are you wanting a stock height truck. Small lift. Ect ect ect. Do you had the springs? Are you building a driver or a wheeler? More information helps us help you. Have you seen a truck on here that you trying to make it like. Might be able to "copy" parts and hanger locations. Good luck hope this helps.
AND DONT FORGET TO READ. It will save you more headache than you can imagine.
Old Apr 30, 2015 | 11:52 PM
89hilux1's Avatar
thanks for the tip
Old May 3, 2015 | 01:11 PM
jaggamuffin's Avatar
I have a 2wd 1988 exteneded cab. is there a turbo kit anyone knows a bout?
Old May 6, 2015 | 10:20 PM
89hilux1's Avatar
look up 22re turbo kits on ebay or on google or if u want i know a person that has one if ur intrested pm me
Old May 6, 2015 | 10:24 PM
89hilux1's Avatar
im making it to be a farm truck and a off road and on road all in one pretty much just need to figure out how to put a toggle and push button in but its being a pain so far but im tring to get everything else done then do the sas after
ladybugRC
458
Aug 21, 2020 10:41 AM
Dale Johnston
11
Oct 31, 2015 10:22 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Flightguy
Oct 2, 2015 05:34 PM
Cycles
Sep 29, 2015 06:37 AM
