PDA
View Full Version : Solid Axle Swaps, All Years
Pages : 1 [2] 3 4
  1. TG Front Spring Bushing Options?
  2. Trail gear standard or hd springs for 2lt diesel pick up
  3. 2WD vs. 4WD SAS please help!
  4. Removing junkyard axle
  5. Opions please SAS im kind of a newbie
  6. Steering Knuckle Leak?
  7. 93 T100 diesel conversion project
  8. Sas swap, where to gusset frame for hard wheeling?
  9. SAS alignment questions
  10. coiloverd four liked tundra
  11. Square DS joint options
  12. Sheared 5 studs off my steering hubs and I can't find the right studs from toyota
  13. Sheared 5 bolts off my steering guns
  14. what parts do i need?
  15. Another another SAS thread
  16. URGENT Towing a SAS prepped vehicle
  17. Wheel Studs don't work?
  18. 1990 2door 4runner SAS slow build
  19. SAS in stock location..
  20. new to toyota axles
  21. Rear shock mount questions
  22. SAS Brakes NEED HELP
  23. Sas best pricing
  24. SAS Knuckle Gusset and Diff Cover Welding Questions
  25. TG Front springs too high?
  26. Front driveshaft angle/length?
  27. Quick SFA prep question
  28. 1990 4runner axles help?
  29. SAS questions
  30. FJ80 SAS, 5 Speed swap?
  31. E-locker Questions
  32. Need some help
  33. SAS Vendors
  34. Drive shaft
  35. need help!
  36. does anyone have a front drive shaft for an 85' pickup forsale
  37. looking for some detailed threads I would really appreciate the help!
  38. Front axle help from 83 yota
  39. Straight axle swap for 86
  40. How much stronger is 9.5" over 8" ? Thinking about swap
  41. SAS prep, where do i start?
  42. 87 sas how much lift do I need for 35s
  43. 94 SAS parts questions
  44. 99 SAS preparation and parts questions.
  45. SAS steering question?
  46. Hunt4Steve's SAS back online
  47. first SAS need some advice on things
  48. 96 Tacoma SAS Build
  49. contemplating sas need advise
  50. HP front third and spline count questions?
  51. Solid Axle Rebuild
  52. Best axles for a swap
  53. 1995 ext. cab pickup sas
  54. can you use 4 cylinder gears up front and v6 gears in the back at the same gear ratio
  55. my yota
  56. Question: 3.4L & SAS conversion from Tacoma to Pickup
  57. Need some advice, possible SAS.
  58. 92 lift springs.
  59. complete 83 under a 2wd 91
  60. 1988 toyota pickup 22re 2wd solid axle swap
  61. 3am sas
  62. What Front SAS Axle For 2002 4Runner??
  63. Longer Knuckle Studs!!
  64. 1995 Toyota pickup SAS
  65. Bump stop size
  66. Another SAS Thread
  67. Future plans and advice for sas
  68. Toyota high steer: position IFS box
  69. Question: Tundra Brakes on a SAS with IFS outers?
  70. 4th gen tacoma SAS... anyone done it?
  71. Is this the front axle I want for SAS?
  72. trail gear pitman arm sucks
  73. My Reg. Cab SAS
  74. stock drag link and tie rod question
  75. SAS High Steer Problems DANA 44 HELP
  76. homemade high steering question
  77. Brake lines
  78. 4cly vs. v6 ring and pinion
  79. Stud messed baddddd
  80. 87 stock runner leaf spring lengths with sas conversion
  81. Silicone or gaskets
  82. 3rd gen sas questions
  83. 85 axle for my 88
  84. revolver shackle question?
  85. Knuckle ball cleaning
  86. does this set up look right?
  87. 5" trail gear springs vs. gm 63's
  88. Will ifs hubs fit a 1981 solid axle
  89. 86 runner, trying to keep it as simple as possible
  90. locked rear flex on dry surface
  91. 1987 4runner build need opinions
  92. offset my wheels vs spacers
  93. Is anyone looking for a cheap solid front axle?
  94. Pitman arm Flex at steering box
  95. Grease issue
  96. question on sas axles and ifs spindel to hub
  97. steering & Knuckle questions
  98. 96 4runner SAS TG frenched
  99. 1992 solid axle swap
  100. New SAS, shackle angle help needed
  101. Ifs eliminator and rear leaf swap problems
  102. IFS pitman arm stop bracket needed for SAS?
  103. project Cookie Monster~ 86 pickup SAS on tons
  104. solid axle swap into a 95 pickup
  105. 35s on a 2nd gen
  106. CV shaft front and Rear?
  107. ride height problem
  108. solid axle guru question
  109. what size tires is everyone running
  110. oil pan swap question
  111. Wheel hub housing worn groove
  112. IFS --> SAS What can I take with me?
  113. Steering Stabilizer questions
  114. DD your sas
  115. solid axle swap v ifs lift.
  116. MC backing plate eliminator
  117. broke the knuckle bolt, advice?
  118. T100 sas
  119. 90 ext cab sas questions
  120. e brake help
  121. Axle width question
  122. speed wobble ever since new rims.
  123. SAS then truck won't go over 60mph. Vibrates bad at 45??? HELP!
  124. quick sas question
  125. toyota drivin liberty
  126. Three link done easy, or just pipe dream?
  127. 84 Landcruiser SA swap into a Hi-lux
  128. My dream is happening-SAS
  129. front springs
  130. Installing cone washers in warn hubs
  131. 84 Reg Cab Frame swap with my 93 xtra cab
  132. 92 pickup 4WD to 92 2WD pickup Frame? IFS?
  133. Frame tube design?
  134. Back Spacing and Wheel Spacers
  135. Hanger differences
  136. Who used a T100 pan on their SAS and who didn't
  137. What do I have?
  138. How to measure front driveline length after SAS?
  139. My SAS Build And MUCH More
  140. Decision time!
  141. SASing a 2001 runner
  142. ifs p/s box tap for hydro assist?
  143. Sky's 9" springs?
  144. Tacoma Brake Conversion
  145. What shock length to run?
  146. quick sas ? on a 92 pu
  147. 6 shooter knuckles on MC arms ??
  148. my little sas
  149. Shock lengths $20-$25 napa shocks lifetime warranty
  150. 3-Link Flexing
  151. SWAMPERS SAS baby!
  152. Rear Shock Mounts Please Advise
  153. any one running the sky offroad 9in springs??
  154. Tacoma SAS
  155. 86 p/u sas. Final questions. Brake line routing? Steering adjustment?
  156. Steering Clunk, SAS
  157. Need verification on front spring hanger position and shackle angle please
  158. Road worthy sas...
  159. Please identify this piece of IFS bracketry
  160. Davez Offroad SAS kit?
  161. 03 taco sas
  162. Anybody know? Tacoma PRERUNNER TRD offroad rear axle same as 4x4 Tacoma Rear Axle?
  163. 94 2wd pickup power steering box on my 81 4x4
  164. 94 ext. cab SAS. Help for the rear!
  165. MaK92-4RnR's 4Runner SAS
  166. SAS spring selction???
  167. Installing used 5" tg leafs
  168. Can I use a rear slip yoke on the front?
  169. URGENT QUESTION! about steering knuckle shims
  170. 3'' hd SaS and 63'' rears and 3.4 swap. 90 4runner
  171. 3inch hd sas question I NEED ANSWERS FAST
  172. Biggest tire size with Trail Gears 5" SAS?
  173. Gm 10 bolt for sas?
  174. What are smoothest riding shocks for SaS other than bilstein
  175. Torque specs!!
  176. Help! Bearing stuck on lower knuckle cap
  177. Should I ?! (SAS)
  178. 1980 toyota chev axle swap
  179. lug studs
  180. Drivability of SAS'd 92 P/U
  181. 92 toyota 2wd converted to sas 4x4
  182. Idea: 1980's Toyota 1 ton dually ... SAS conversion??
  183. build questions! (SAS)
  184. FJ60 front axle???
  185. 92 Xcab 3" SAS
  186. Can you help me identify the parts I need on this SAS
  187. I need help/opinions!!
  188. FJ40 leafs for 1st gen SAS?
  189. 96' SAS Project Stranded! Need help!
  190. 94 2wd frame 93 4wd powertrain 84 axles
  191. What do I have boys? Just bought an old rolled runner with a SAS...
  192. aj923s 2wd to 4wd sas with questions
  193. 2003 Tacoma SAS HELP!
  194. Leaf spring help
  195. Anyone have any spring under axle advise?
  196. Steering setup..?
  197. complete front drive shaft?
  198. Front axle moved forward ??
  199. 1995 P/UP SAS BUILD UP Your Advice Please
  200. 97 tacoma sas
  201. SAS steering rubbing and binding
  202. Pitman arm? after sas
  203. Twistedyota's 87 SAS
  204. 93 p/u sas
  205. recon for SAS need advice from folks in Hawaii
  206. Does this RUF caster angle look right?
  207. u bolt flip and axle shim question?
  208. Dana 44 ID
  209. 3-link front..what about the rear?
  210. 89' Yota 83' SAS/E-Locker/RUF
  211. Does this shock mount position look right?
  212. lower knuckle cap...
  213. 1990 Pickup SAS
  214. 89 xtracab sas
  215. Solid Axle Swap on my 91 Pickup..
  216. Ball joint taper..
  217. Who's Running 35x12.50x15 on their SAS
  218. Cross member question
  219. ABS issues with SAS
  220. FJ 60-62 axle on 3rd gen 4runner
  221. SAS opinions needed
  222. Lets Start SAS'ing
  223. SAS Plans, Feedback requested
  224. Argghhh!!! Another bent axle housing discovered too late! Can it be saved?
  225. Help! SAS spring size question...
  226. Pinion angle..
  227. 86 4Runner wants a SAS
  228. Please Help- Need Front Leaf info
  229. LOW lift w/ High-Steer?
  230. frame tube question?
  231. 1999 SAS and Build-up
  232. Pitman Arm 1st gen.
  233. Kycrawler's (low) SAS
  234. UK Surf (4runner) V8 & SAS
  235. 89 ext cab SAS
  236. Any pics or thoughts on frenching rear spring hangers on a 2nd gen 4Runner?
  237. 04 dc tacoma sas advice
  238. Question about Scout II dana 44's under a yota
  239. Suspension ?'s for 4BT and 37's
  240. Addicted Offroad Tacoma SAS
  241. Correct sump for Lexus V8 & SAS
  242. Solid axle shaking questions
  243. 88 4Runner SFA Install Redo w/TG Hanger Kit and 3” springs, longwinded & pic heavy
  244. help carrier setup
  245. Dbcfr's unwitting SAS thread (as told by Mountain Cop)
  246. Questions/concerns regarding front spring hanger and alignment, pics included
  247. ABS on the fritZ! HELP!!!!
  248. 1st gen 4runner SAS frame height (front/rear)
  249. knuckle studs
  250. SAS Questions
