URGENT QUESTION! about steering knuckle shims
Old Dec 4, 2011 | 10:44 AM
pyrojoe22's Avatar
This is the only thing keeping me from getting my axle finished. It's out of an 85 pickup. I put the stock shims back on the steering knuckle and only get 5-7lbs of drag. The felt isn't bolted to the back side, and I don't have the axle shafts in the axle housing (I didn't think you were supposed to?) What do I need to do to get 12-15lbs of drag? Or is 5-7 fine? All parts on this axle now are Trail-Gear. They also sent a shim kit with their knuckle rebuild kit.
Old Dec 10, 2011 | 09:40 PM
pyrojoe22's Avatar
Still waiting for a correct answer on shimming. I will be running 37" tires. I've been told to shoot for 15 lbs of drag. I've also been told to keep the amount of shims on top the same as the bottom, and I've been told differently to keep the stock shim on the bottom and only increase or decrease on the top. I'm sick and tired of ripping the steering arms back off, and I'd like a straight answer so I can get this thing put back together right
Old Dec 11, 2011 | 06:55 AM
waskillywabbit's Avatar
Honestly, I haven't checked the drag on one in years and just put the stock shims back on if reusing the stock knuckles. I go by feel and torque everythign to FSM specs. Never had an issue.
If you've upgraded to six shooter knuckles or somethign then you need to get it right.
:wabbit2:
Old Dec 13, 2011 | 08:36 AM
skunkwhat's Avatar
I would take a shim out of the top and bottom if i was you. Bring that drag up a little bit more.
Old Dec 13, 2011 | 09:37 AM
4Crawler's Avatar
X2, thin out the shim stack a bit and that should do it:
- http://www.4crawler.com/4x4/CheapTri...ld.shtml#Shims
Old Dec 13, 2011 | 12:17 PM
pyrojoe22's Avatar
Went from .04" on top and bottom on both sides with 5 lbs drag on passenger and 7 lbs on drivers,,, to .026" on passengers and .03" on drivers both with a perfect 15 lbs on each now. Thanks to Mr. 4Crawler for the quick and correct response on how to address this issue! You're a life saver!
To potentially save people some head ache, here is the list of shims that came with my Trail Gear knuckle rebuild kit. I think they should be the same for all kits.
.04"
.03"
.02"
.01"
.008"
.006"
glowz825
Jan 25, 2022 09:28 AM
delmert
Sep 30, 2015 04:34 PM
Up&Down
Aug 11, 2015 10:04 AM
gillesdetrail
Aug 3, 2015 04:43 PM
gmonnie123
Jul 26, 2015 02:44 PM
