frame tube question?
Old Feb 27, 2011 | 10:44 AM
yoterr's Avatar
allright so when i was drilling out the holes in my frame i got a lil frustrated and it was dark and i started the hole in the wrong spot.. about 1/2 an inch to far back...i re adjusted and drilled it right but i was wondering about what to do with the wallerd hole on the outside frame rail...was thinking about just drilling another hole in some plate and welding it on in place to cover the hole and for something to weld the frame tube too.. but im not sure..what do you guys think
Old Feb 27, 2011 | 11:10 AM
blake.nemitz's Avatar
ya just plate it or fill, it with a fat bead if it is skinny enough
Old Feb 27, 2011 | 11:21 AM
yoterr's Avatar
yea i just wasnt sure if the plate would mess up the shackles or the tubes..how thick of plate u think?
Old Feb 27, 2011 | 11:29 AM
2DoorRunner's Avatar
Can we get a picture?
Old Feb 27, 2011 | 11:31 AM
yoterr's Avatar
i spose...kinda embarrassed but ill get one up either tonight or tmr
Old Feb 27, 2011 | 11:49 AM
wifes4now's Avatar
just weld it closed and grind it flush,then drill new hole
Old Feb 27, 2011 | 12:04 PM
4Crawler's Avatar
Well, the frame steel is only about 1/8" (3mm) or so thick, so that should be sufficient. Just don't want it thicker than the amount the tube sticks out past the frame. Or just pick up a large flat washer and drill it out to fit if you don't have any scrap to use. That is how I repaired the front of my frame when the steering box ripped out the sleeves welded into the frame (original All Pro crossover steering install w/o any plating). Used washers to fill in where the frame tube collapsed, then plated over that and it has held fine for 13 years now.
Old Feb 27, 2011 | 06:22 PM
yoterr's Avatar
cool, thats what i was wondering ill get some plates made up...i might do it to the other side so it doesnt look so akward?
young buck
18
Aug 27, 2018 02:40 PM
DrZero
18
Jul 24, 2015 11:31 PM
Backcountry411
Jul 24, 2015 08:06 AM
Fundy Rider
Jul 16, 2015 01:35 AM
