Pitman Arm 1st gen.
Old Feb 15, 2011 | 12:45 PM
808Yodi's Avatar
Exclamation Pitman Arm 1st gen.
'86 4Runner 22re
--Completing a solid axle swap (dodge 86 Dana front).
Got a question about the pitman arm -- never removed or replaced one before but i can use the stock steering arm if I can adjust the placement of the pitman arm's rotation. Meaning that if you can place the pitman arm at any degree from the beginning...i can just spin it further out so that it will work for the driver;s side steering arm on the dana. But, if the pitman arm only locks into one place for install...then it wont work.
ANYONE know bout the placement of the pitman arm on install?
Does it only go in on spot or can we manually place the pitman arm on the bolt??
aowRS
Sep 13, 2017 08:22 AM
crash813
Sep 27, 2015 07:15 AM
Project90
Sep 24, 2015 11:40 PM
JRB4Runner2015
Sep 20, 2015 12:29 AM
icentropy
Sep 10, 2015 05:03 AM
