Bump stop size
Old Jan 2, 2013 | 07:27 AM
Toy-thrasher's Avatar
Bump stop size
Hello everybody, so far i have learned alot from reading your old threads but now i am to the point on my '86 4runner to put the bump stops. I'm curious as to the size of the stop. I can get 4 and half inch tall bumpstops or 2 and half inch tall ones from low range offroad. This is my first time building a crawler so any advise would be appreciated. Is taller better? Does size matter on this? Which size would you get?
Thanks
Old Jan 5, 2013 | 06:32 AM
Alrighty then
Old Jan 5, 2013 | 12:13 PM
4Crawler's Avatar
Use whatever size that will limit your springs from going past flat. So just drive one side of the truck up on a ramp until the springs flatten out and then measure the clearance and size the bump stop off of that.
Old Jan 5, 2013 | 01:03 PM
Got it. Thanks man!
Old Jan 5, 2013 | 01:06 PM
4Crawler's Avatar
I run a shorter bumpstop then make a spacer to raise or lower it to the desired height:
- http://www.4crawler.com/4x4/4R_suspe...html#Bumpstops
Old Jan 5, 2013 | 01:19 PM
Good info 4crawler. I really like the spacer part for sure. I wasn't sure about softness difference between the two sizes. Taller seemed like the way for me but now I see you liked it firmer than rectangle ones you used to use, which is what I was going to get.
Old Jan 5, 2013 | 01:41 PM
4Crawler's Avatar
I run a taller bumpstop in back:
I need to re-orient it so it is lined up to the axle instead of parallel to the frame rails to help stop if from folding over like above. The taller bump stop will give a more progressive stop as it compresses while a shorter one is more of an abrupt stop.
Old Jan 5, 2013 | 02:15 PM
Wow that does look like some serious arch. Thanks again
andrewtexas123
Jul 6, 2016 01:49 AM
punks_is_4x4
Aug 21, 2015 01:35 PM
Gravel Maker
RuffStuff
Aug 6, 2015 04:27 PM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
icentropy
Jul 11, 2015 07:21 AM
