Pitman arm? after sas
Old Jun 15, 2011 | 05:45 AM
Georgia Boy's Avatar
I just got done with my sas on my 87 truck,I used wabfab hanger kit with trail gear hy steer.My problem is the balljoint that goes in the pitman arm is hitting my steering arm.So could I just get a flat pitman arm to solve the problem.Thanks for any info
Old Jun 15, 2011 | 05:49 AM
blake.nemitz's Avatar
post up a pic that would help alot.
Old Jun 15, 2011 | 05:58 AM
I will take one when I get off work and try to post it.The joint only hits when the driverside does any flexing.When the truck is parked it doesn't hit but is very close to the steering bar.
waskillywabbit's Avatar
Did you move the IFS box?
Post pics.
:wabbit2:
Old Jun 15, 2011 | 06:39 AM
I did not move the box,its like the pitman arm has to much of a drop.I have read about moving the box but was kinda hoping I wouldn't have to.I will try to get a pic when I get home.Trail gear said they would trade me a flat arm for the drop arm
Old Jun 15, 2011 | 08:26 AM
i didnt have to move mine and when you look at the side the tie rod is ahead of the drag link, however when it flexes the axle moves back and it clears by a 1/4 inch. are you using the ifs arm with an adapter at the draglink end? my axle is 2" forward from stock
Old Jun 15, 2011 | 08:29 AM
hopefully you can compare or at least see what i did
Old Jun 15, 2011 | 08:33 AM
i think i misread what your problem is. is the ball joint itself touching the pitman arm? i though you meant the drag link
Old Jun 15, 2011 | 08:56 AM
Thanks for the pics blake,My axle is moved foward also,the joint that the draglink(top bar) connects to the pitman arm is hitting the steering bar(lower bar).It looks like in your pics u have a good bit of space in between the 2 bars mine are very close to each other. I am using the pitman arm that trail gear sent with the hy steer.My stock ifs arm was the same as the tg arm.
Old Jun 15, 2011 | 09:31 AM
What springs? Hanger placement?
:wabbit2:
Old Jun 15, 2011 | 09:39 AM
To be honest when I was looking for a donor axle I bought a whole truck with a 4 " lift for $300.00 and used the rear leaf springs off it. Don't know what kind they are though.
Old Jun 15, 2011 | 12:19 PM
DeathCougar's Avatar
How far forward is your axle? I moved mine 5 1/2" forward and couldn't use Hi-steer because of it. I still used the trailgear pitman arm though.
Old Jun 15, 2011 | 12:28 PM
I need to get some pics,its moved maybe 2". If the pitman arm didn't have so much of a drop it would work fine.The ball joint on the draglink hits the steering bar.It hits when the driver side suspension moves,Dont know if it matters but its got 4" suspension lift with 3" body lift with 38.5 boggers.
ladybugRC
458
Aug 21, 2020 10:41 AM
ktm192k
Oct 1, 2015 08:47 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
Toys4parts
Sep 26, 2015 01:56 PM
Project90
Sep 24, 2015 11:40 PM
