e brake help
Old May 11, 2012 | 05:36 PM
Dreidel's Avatar
e brake help
ok so i recently did a sas on what was my 2wd how ever i lost the function of my e brake because it was rubbing on the drive shaft can somebody help me get an idea of how to set it up so its out of the way of the driveshaft and i can get the brick out of my passenger seat
Old May 14, 2012 | 09:26 AM
Low Range's Avatar
FormerVendor
Ebrake
Do you have any pics you could post up? We could get some ideas on different routing.
Do you have a RF1A gear driven t-case?
http://www.lowrangeoffroad.com/toyot...case-info-rf1a
Sometimes new cables can be purchased and re-routed so that it will still work as factory, but sometimes there is no other option than going to driveline style ebrake kits.
Old May 14, 2012 | 03:33 PM
Dreidel's Avatar
ok new idea i like the idea of the tcase brake witch is what i was thinking of making my own problem is i need to find a decent mechanical caliper that will hold the weight of the truck on a decent grade
there is a cnc plasma cutter at school and i have autocad 2012 on my laptop so i was
going to make a crossdrilled rotor that bolts in between that driveshaft and the tcase make a mount that bolts to the tcase use the original brake cable that goes to a mechanical caliper i think i found one i has 8 in squared of gripping area but i cant find a price on it or a place to buy it, do you think a decent gokart could brake work?
1uzRunner
63
Nov 10, 2018 03:58 PM
old87yota
Sep 9, 2015 12:39 PM
fabing455
Sep 7, 2015 08:08 AM
Scatterbrain
Sep 3, 2015 06:46 PM
