quick sas ? on a 92 pu
Old Feb 13, 2012 | 05:05 PM
BIGTOY88's Avatar
Does anybody know what the two hoses are for that came from the engine compartment and into the ifs axle housing??? I removed them when I took the ifs off then followed them up into the engine compartment where they hooked onto two nipples on the top of the passenger side of the engine compartment. I removed the hoses from the two nipples but have no idea what they were for or if I need to cap the nipples. Some kind of front diff sensor maybe??
Anybody have any insight on this? I can post some pics if nobody knows what im referring to.
Old Feb 13, 2012 | 05:22 PM
toyota4x4907's Avatar
Vacuum lines for the ADD....
Old Feb 13, 2012 | 05:46 PM
BIGTOY88's Avatar
Add???
Old Feb 13, 2012 | 05:48 PM
BIGTOY88's Avatar
ADD??? do I need to cap off the nipples they connected to?
Old Feb 13, 2012 | 05:57 PM
James Woods's Avatar
ADD is a way of locking and unlocking the front hubs rather than using manual locking hubs it is operated from inside the cab, it is operated on vacuum, so yes you need to cap off the nipples otherwise you will have a vacuum leak.
Old Feb 13, 2012 | 06:10 PM
BIGTOY88's Avatar
Thanks for the info. Makes perfect sense now.
Old Feb 13, 2012 | 06:13 PM
yotaman85's Avatar
Originally Posted by James Woods
ADD is a way of locking and unlocking the front axle rather than using manual locking hubs it is operated from inside the cab, it is operated on vacuum, so yes you need to cap off the nipples otherwise you will have a vacuum leak.
fixed!
Old Feb 13, 2012 | 07:20 PM
Teuf's Avatar
Short and sweet, a happy ending.
Old Feb 13, 2012 | 07:21 PM
Originally Posted by yotaman85
fixed!
Ha ha thanks, my mind was thinking faster than I could type.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
Toys4parts
Sep 26, 2015 01:56 PM
Project90
Sep 24, 2015 11:40 PM
