89 xtracab sas
Old Apr 18, 2011 | 10:27 AM
jontoptek's Avatar
89 xtracab sas
I had this sas done at a 4x4 shop, here in the philippines
its a 4link coil suspension, using 80 series lc springs, mounts, and rear control arms
drove it on the freeway, took it up to 70mph, its stable and ok, exited the freeway about 20mph, hit a small bump and the truck shook violently
dont want to bring it back to the shop, I'm thinking of just fixing it myself.
plan is, to upgrade to Hi steer, and check caster angle
what do you guys think? can anyone id this axle?
any help would be appreciated
thanks,
Jon
Old Apr 18, 2011 | 02:39 PM
jontoptek's Avatar
will post pics, as soon as I figure out how to
Old Apr 18, 2011 | 03:06 PM
dropzone's Avatar
Fossilized
try photobucket.com
your pics are TINY
Old Apr 18, 2011 | 09:08 PM
jontoptek's Avatar
click on the photo to enlarge
Old Apr 19, 2011 | 04:16 AM
waskillywabbit's Avatar
Front looks like it has a panhard bar 3 link not a 4 link.
High steer would help but not sure where it will fit with all those monkey bars. Full hydro might work better.
:wabbit2:
Old Apr 19, 2011 | 12:22 PM
yotaman's Avatar
Your panhard and draglink should be at the same angle. The frame end of the panhard needs to come up or the axle end needs to come down. It would also be better if the panhard was longer.
Setting up a good 3 link is not for everyone.
Old Apr 19, 2011 | 03:59 PM
jontoptek's Avatar
thanks for the reply
thru my research on the net, thats is what I thought I needed to do, to get the angle of the panhard and the draglink the same
Old Apr 19, 2011 | 04:12 PM
scuba's Avatar
The axle appears to be out of a 79-81 Toyota mini truck. If it was an FJ80 axle it would be ~6-8" wider than your rear end and the tie rod would be on the back of the axle under a high pinion diff.
Old Jan 26, 2012 | 05:02 AM
jontoptek's Avatar
click on the pic to enlarge
decided to get rid of the monkey bars, and do it right. front is a tg 3inch kit, it is so much better. at times I get a clunk when one side of the suspension is compressed, any ideas?
Old Jan 26, 2012 | 05:06 AM
jontoptek's Avatar
more pics
Old Feb 13, 2012 | 05:29 AM
rattlewagon's Avatar
....so you ditched your 3 link for leaf springs.....?
Should have just fixed the 3 link.
Old Feb 13, 2012 | 08:50 AM
bttrs's Avatar
x2 that makes not sense, big waist of money
Old Feb 16, 2012 | 01:49 AM
jontoptek's Avatar
its a 4 link that was not done properly, I was experiencing scary violent death wobbles
decided to go the much simpler leaf spring setup
Old Feb 16, 2012 | 04:27 PM
bttrs's Avatar
glad you got it straightened out but sorry you wasted the money for a 4 link and ended up leafed.
RickyD
Oct 2, 2015 07:53 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
Toys4parts
Sep 26, 2015 01:56 PM
Project90
Sep 24, 2015 11:40 PM
Flying91
Sep 10, 2015 03:41 PM
