broke the knuckle bolt, advice?
Old Jun 1, 2012 | 11:59 AM
lastname_firstname's Avatar
Well I didn't personally break them, but two of the studs that hold the steering arm on were broke on my axle when I got it...I've tried drilling them out and broke 5 bits, my EZ out, and am out of ideas...anybody know how to get these suckers out?
Old Jun 1, 2012 | 12:07 PM
waskillywabbit's Avatar
Removed the knuckle?
Broken inside threads or sticking up?
Pics would help.
:wabbit2:
Old Jun 1, 2012 | 12:35 PM
Removed knuckle in the middle of a rebuild and the bolts broke inside the threads. Sorry working ALGOL post up pics when I can
Old Jun 1, 2012 | 12:37 PM
MaK92-4RnR's Avatar
remove it, put it in a vice, and if you can grab it with vice grips. slowly back it out. if not. you need a recovery bit.
Old Jun 1, 2012 | 12:40 PM
Ahhh stupid phone! I'm in the process of rebuilding the axle b4 it goes under the truck and I'm just gonna use the stock studs, but my problem is that these things seem to be made out of some sort of super steel and they're breaking everything I throw at them. I don't own a drill press and am curious if they make bits specifically tailored to do this kind of drilling.
Old Jun 1, 2012 | 12:44 PM
No access to the studs. They're broke off inside the threads and I'm pretty certain its because the bolts are siezed
Old Jun 1, 2012 | 12:45 PM
Not sure what a "recovery" bit is, or where to get one...
Old Jun 1, 2012 | 04:09 PM
Two hammers, a torch, liquid wrench, high speed drill bits, two homies and a 5th of vodka later - we are go for extraction!
Old Jun 3, 2012 | 07:57 AM
dntsdad's Avatar
Knuckles are cheap. You could have probably bought a used one for what you lost in damaged bit and easy outs.
Pirate will have a bunch.
glowz825
Jan 25, 2022 09:28 AM
icentropy
Sep 16, 2020 02:47 PM
oldirtydirt
Feb 23, 2020 09:30 AM
msane99
Jul 27, 2015 06:14 PM
Iceman4193
Jul 15, 2015 04:48 PM
