04 dc tacoma sas advice
Old Feb 4, 2011 | 02:50 PM
from_CO_2_AK's Avatar
i have an 04 dc taco and am looking into doing a sas while Im visiting my mom in colorado. what Im stuck on is fox coil over with links or the trail gear kit hopefully with fox also. i would like the ride of the coil overs but want advice on whats gonna have more maintenance and what should hold up better in alaska when its -40 for a month. Also the work will either be done by addicted off road or moab 4x4 outpost(m40). Ive searched and haven't found much for long term maintenance or if the cold will have any negative effects. any thoughts or opinions appreciated.
Old Feb 4, 2011 | 03:32 PM
Tofer's Avatar
Sponsor
Take pics!
Old Feb 4, 2011 | 04:43 PM
894x4pickup's Avatar
Links will perform, but tg will get you there. Keep us posted!
Old Feb 5, 2011 | 09:38 PM
what do you mean links will perform
Old Feb 5, 2011 | 10:13 PM
toyota4x4907's Avatar
Hasn't been -40 for a month this year so far
Knock on wood...
Old Feb 6, 2011 | 08:02 AM
blake.nemitz's Avatar
i would go with leaves in -40 you want it to be as simple and reliable as you can.
Old Feb 6, 2011 | 08:38 AM
scuba's Avatar
A properly setup 3 link or 4 link system will out perform (think flex, ride, etc..) leaf springs any day.
Old Feb 6, 2011 | 11:43 AM
thats true scuba but its also alot more to brak and wear out, its nice to just replace bushing in a spring rather than heims and rod ends, but thats just my opinion, im building my rig, sounds stupid, for doomsday, it will have mechanical injected diesel, will run in the event of an emp attack, and leaves at all four corners. i need it to be as reliable and as simple as possible. to each his own and to be honest if i had to coin to build another crawler it would definatly be a 3-4 link setup and be wicked. i guess the question to ask is what kind of mechanical ability do you have a 3-4 link to some is alot harder to set up correctly than hangers and shackles. if i had the cash i would get the trail gear kit for the bracketry for the link setup and measure 100 times before welding anything, and i would replace the crappy tg ends with higher quality ones when they wear out.
Old Feb 6, 2011 | 11:45 AM
i guess too the cold could have a negative effect on leaf springs as they can get a little brittle at twemps that low, i guess you could break one but if it was me i wouldnt want to wheel in weather that cold ha ha
Old Feb 6, 2011 | 11:52 AM
Exactly, if you can get by the initial setup, fab work, and cost, you will be way happier in the long run.
Look up some link buildups on pirate:
http://www.pirate4x4.com/forum/forumdisplay.php?f=12
and start reading! Also, 4wheelunderground has excellent reading on roll axis, understeer, antisquat, etc. (http://www.4wheelunderground.com/)
Old Feb 6, 2011 | 11:56 AM
You are talking about you.
trail gear kit for bracketry? ever heard of ballistic?
Im interested in the OP's build, not yours.
Old Feb 6, 2011 | 12:45 PM
4runnerRandy's Avatar
What ever you do, take lots of pic's for a build up thread. Not many double cabs on a SAS. I look foward to seeing it.
Old Feb 6, 2011 | 06:37 PM
ScottyC's Avatar
TG ends have actually lasted longer than my Ballistic ends up front. I currently have one that needs attention in the front. All eight TG in the rear are fine. Both are good quality link ends regardless though.
Old Feb 6, 2011 | 06:40 PM
ScottyC's Avatar
If you want to talk over the leaf vs. link setup, give me a call at the shop. 970-420-4198
Old Feb 7, 2011 | 05:11 AM
hey man just throwing it out there since he stated reliability out in the arctic enviroment where it really counts. and i checked out ballistic fab cool stuff. and scotty i guess i shouldnt believe everything they say about trail gear!! what ever you do man an 04 taco would be sweet sas'd cant wait to see the writeup
Old Feb 9, 2011 | 11:39 AM
thnx i appreciate all the input ill be making my decision in the next week and will post plenty of pics all the way through.
Old Feb 9, 2011 | 11:41 AM
any one have experience with fox in cold weather
Old Feb 15, 2011 | 06:00 PM
so i put the order in today for the trailgear kit with 4 inch leafs. with rock assault housing arb air locker with 4.88. gonna be running 35s. hope the proportions arent off. maybe i should have got the 3inch. either way im stoked they told me it will be in friday or monday all i have left to get is rubber and a spindle. will post the before pics tomorrow. and the rest when were finished hopefully my new corbuea seats are in before so its complete when she rolls out the shop. being i have to get back to alaska in the next two weeks to get back to work
Old Feb 24, 2011 | 08:39 PM
The transformation has begun if all goes well I'll be rolling round in my sasd locked f and r taco on 35s Monday night. Ran in to small snag as the bumper needs modified since It mounts up to the bottOm of the frame little cutting and welding. Having custom ends made since iv read so much about the tg ones failing. Anyways post pics tommorow night
Flying91
45
Apr 11, 2024 04:39 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
94whiterunner
Jul 12, 2015 07:15 PM
Poncho0206
Jul 10, 2015 06:21 PM
