SAS opinions needed
Old Mar 30, 2011 | 01:09 PM
yoterr's Avatar
SAS opinions needed
allright been a while since ive been able to work on my truck last...so here goes.. i cut the IFS crap off about 8 months ago and welded on the front hanger about an 1" and 3/4 or so forward...at the time i was planing a V8swap some time in the future.. but figureing out how expensive they are its not going to happen .fast forward to day and i got my shackle tubes welded in and everything mounted back up...and without a V8 theres no way stock springs are going to work.. i could barely get the spring mounted in the shackle..so heres the choices
cut and re-weld hanger back in its proper place (fully welded on mind you).....
rears up front swap..(math works out perfect but will prolly have to move steering box...)
or waggy springs backwards? 48" is long enough and maybe backwards 26" side facing forward my axle wont be too far forward like the RUF swap...have to do some measureing to make sure...
i dont have a whole lotta cash to swing around at the moment so im swinging towards the cut n re-weld...but i dunno if ill mess somthing up in the process..what would you guys do?
Old Mar 30, 2011 | 01:45 PM
FourGee6Tee3's Avatar
Rears up front for sure. They are readily available extremely cheap flex well and are very strong. The trick is finding the right pack for your needs. Steering box is not that hard, you will be glad that you did it.
Old Mar 30, 2011 | 02:34 PM
yoterr's Avatar
yeah that was what i was thinking..but i dunno if i can move my steering box far enough forward.. for a RUF ill have to measure and see
Old Mar 30, 2011 | 03:09 PM
yoterr's Avatar
up....
Old Mar 30, 2011 | 04:31 PM
yoterr's Avatar
uuppp
Old Mar 30, 2011 | 05:26 PM
TOYOTA 1's Avatar
x2!
i got mine far enough forward with ruf and hanger moved forward 3/4",
i had to trim the body mount slightly though.
measured yet?
Old Mar 30, 2011 | 05:32 PM
yoterr's Avatar
haha no its pouring outside...wich is why im inside trying to figure stuff out...i have yet to find any good pictures of how to move the steering box forward..any links?
Old Mar 30, 2011 | 05:44 PM
TOYOTA 1's Avatar
https://www.yotatech.com/forums/f152...ierods-189426/
http://www.pirate4x4.com/forum/showthread.php?t=374962
here is a couple that i found real quick using google.. do a lil searching, there is a ton of info on this subject.
Old Mar 30, 2011 | 06:59 PM
yoterr's Avatar
everytime i search i get people's SAS and it just shows how far they moved it...like b4 and after no tech on how to move it lol or what they used
Old Mar 30, 2011 | 07:20 PM
yoterr's Avatar
cool..lol with those 2 links i figured out i just need some 1/4"-3/8" plate and some 1" tubes to sleeve the holes wich can be found at HD makes me a happy kid cuz there isnt many metal fab places i can just go get steel or DOM tube from when i do it ill take lots of pics...
bigjstang
Jun 2, 2025 03:56 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
bryan34w
Jul 6, 2015 05:53 PM
mickyd9990
Jul 6, 2015 09:01 AM
karbin
Jul 5, 2015 11:37 PM
