moving stearing box forward to clear tierods
Old Aug 17, 2009 | 07:02 PM
chuckh's Avatar
I have a 93 4runner sas allpro kit tierods hitting stearing box need imfo& pictures
Old Aug 17, 2009 | 08:39 PM
4Crawler's Avatar
Unbolt it from the frame and shove it as far forward as possible, mark the new bolt hole locations (probably need a steering box installation kit) and mount it there:
- http://www.4crawler.com/4x4/CheapTri...#PowerSteering
Old Aug 18, 2009 | 11:11 AM
RaginYota's Avatar
Remember once you move your steering box forward, you will have extend the steering linkage going to the steering box. I was able to get by TEMPORALLY, buy loosing the clamps under the dash and on the steering box and pulling out the rod, but it was far from safe. About a week later I ended up taking it out totally, cut in half and welded in extra peice. Now it is fit perfect and has survived a Rubicon trip..lol..
Old Aug 18, 2009 | 12:15 PM
4Crawler's Avatar
Or you can use a bolt-in steering shaft extension:
http://www.4crawler.com/4x4/ForSale/...eringExtension
I run a 2" spacer on my '85 with the forward steering box and 3" body lift:
Old Aug 18, 2009 | 03:20 PM
waskillywabbit's Avatar
Plate and sleeve the frame, move the box forward.
Old Aug 19, 2009 | 03:06 PM
YeloSub7's Avatar
I even cut mine to move the box forward even more and rotate it to use a flat pitman arm...
hope thats helps!!
Old Oct 10, 2010 | 07:11 PM
trailyota1's Avatar
Here is a link that may help when you move your box forward, and have to extend the steering shaft:
https://www.yotatech.com/forums/f116...quired-219119/
No cuttin or weldin req!!!
jasonty
41
Dec 23, 2018 01:00 PM
raptor510
Feb 17, 2017 07:11 AM
delmert
Sep 30, 2015 04:34 PM
Scotto6591
Sep 1, 2015 03:24 PM
crashburnoveride
Jul 10, 2015 06:39 AM
