HP front third and spline count questions?
Old Mar 4, 2013 | 12:05 PM
murphyz's Avatar
ordered a high pinion front third and as i was completing the order the guy asked if i wanted HD 30 spline axles. i was under the assumption that all front axles had 30 splines. only the IFS axles came with 27 splines? is this correct?
my truck is a v6 89 4runner and my front axle is a 83 axle but i have no clue if it came from a pickup/4runner or v6/I4?
4x4wire said that all pre 85 axles have 30 splines and would accept a HP front thrid drop in style no need for new axle shafts. is this correct?
Thanks for the help
Old Mar 4, 2013 | 12:13 PM
murphyz's Avatar
desregard wabbit had a link i didnt find til after i posted
sfa= 30--- 27 at wheel end
ifs= not 30
Old Mar 30, 2013 | 08:52 AM
Yopar's Avatar
ifs= not 30
You can get 30 at the wheel end like Longfields, and change your birfields to 30.
Also the HP ring and pinions can come w/ a 29 spline pinion (Nitro Gear and ?), which requires a 29 spline yoke. I dunno if 29 spline pinions are available for regular cut gears though, maybe.
88sasturbotoy
Jan 30, 2026 01:57 PM
kazuya2416
Apr 5, 2024 02:17 AM
oldirtydirt
Feb 23, 2020 09:30 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
icentropy
Jul 14, 2015 10:23 AM
