Help! SAS spring size question...
Old Mar 12, 2011 | 01:24 PM
91AKyota's Avatar
Help! Front spring question...
I have a 90 pickup ext cab with the 3.0 v6. I am doin a SAS here pretty soon and wanted to know if I should go with the HD springs since it is a 3.0 v6 If I don't want the springs to settle too much and lose ride height? Or do the regular springs hold up pretty well with the 3.0 since it is not that heavy for a v6?
Old Mar 31, 2011 | 07:56 PM
upsidedown's Avatar
I would run the HD springs, they will settle but it'll take a little longer. I'm running reguler springs on the front of my crawler and they are already settled after about 7 or 8 runs now my 87 4runner with a 3.4 sits stink bug.
Old Apr 2, 2011 | 10:59 AM
bigarms23's Avatar
if you use 4inch allpro springs than you don't have to worry about hd springs the allpros support the weight of the 3.0 or 4.3v6 rather well and they break in rather quick
Old Apr 2, 2011 | 11:24 AM
muddpigg's Avatar
If you run the "trailcrap" springs you might better go with HD and a replacement plan. My buddy has an old set of 4" allpro that have been run for years that are now supporting a 3.0, he stripped his old '81 to build an '88 4rnr. He even bent a spring running no bump stops years ago, you can notice it in one of the pics. I've watch him beat on them.
https://www.yotatech.com/forums/f37/...feeler-232693/
I'm running 4" but have a 22RE. You could always go up to 5" springs if your that worried.
Old Apr 2, 2011 | 11:59 AM
waskillywabbit's Avatar
There is no need for HD leaf springs except for V8 engine weight or extreme loadings.
Most leaf springs fail due to improper bumpstops or none at all.
:wabbit2:
Old Apr 13, 2011 | 11:10 PM
anthony1's Avatar
I've been running Marlin 4" springs for years without issues....
Old Apr 14, 2011 | 04:59 AM
blake.nemitz's Avatar
:wabbit2:
i have to disagree there wabbit. just because i have 4 in. tg springs and a perfect shackle angle and they were a little soft. i hammered the bumps all the time. i added a leaf and some more progressive bumps and its fine now. the springs were just a tad soft for my aplication and adding the leaf helped more than i can say. by the way hows the taco project coming
Flying91
45
Apr 11, 2024 04:39 PM
justdifferentials
Just Differentials
Aug 30, 2015 08:42 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Gravel Maker
RuffStuff
Aug 6, 2015 04:27 PM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
