Which U Bolt Sizes Do I Need
Old Oct 18, 2015 | 10:10 PM
87toyoda's Avatar
So I'm doing a solid axle swap on my 87 pickup with an 84 front axle. I'm going to make my own u bolt plates, but I'm not sure what size bolts I need. I'm using my rear leafs up front so could I use 3" ID bolts or do they need to be 3 1/8" ID. Also am I correct that one side uses round bolts and the other side uses square bolts? I'm also putting chevy springs out back so should I use 3" ID bolts for them? Any info is appreciated. thank you!
Old Oct 19, 2015 | 10:48 AM
ZUK's Avatar
ZUK
There is a lot of things you have to consider beside that. A tape measure in your hands is the best way to determine what the dimensions are you need. you have the housing in hand.
google is your friend
http://www.pirate4x4.com/forum/toyot...-swap-faq.html
Old Oct 19, 2015 | 11:00 AM
ZUK's Avatar
ZUK
shackle in the rear or front?
Got the money for expensive hi-steer stuff or make your own "basic cross-over" for almost free?
http://www.pirate4x4.com/tech/cross/Cross.html
You already have an IFS steering box in place so half the battle is won.
Old Oct 19, 2015 | 11:05 AM
87toyoda's Avatar
Thanks for info Zuk. I was planning on measuring later, but I'm at college right now and the axle is up home. I just wasn't sure if anybody knew whether 3" u bolts would fit over the axle housing or whether it had to be the 3 3/8" u bolts that the flip kits come with.
Old Oct 19, 2015 | 11:07 AM
87toyoda's Avatar
I was planning on making a crossover steering like on your rigs with the Y arm. I should have everything i need for it except i still need to order the draglink and rod ends.
Old Oct 19, 2015 | 12:50 PM
ZUK's Avatar
ZUK
Y-Arm old school cross-over steering
Here's more info on a Y-arm I did for a buddy on his 1984~85 truck.....
http://board.marlincrawler.com/index...ighlight=j+arm
polo451
13
Nov 20, 2016 07:49 PM
ashersullivan88yota
Aug 23, 2015 12:49 AM
4x422r
Aug 18, 2015 05:33 AM
accuracy
Aug 6, 2015 12:32 PM
Gevo
Jul 29, 2015 11:15 AM
