PDA
View Full Version : General Vehicle Related Topics (Non Year Related)
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. Supercharger Sound
  2. No Spark. NEED HELP!!
  3. Fuel gauge reading wrong?? Or, E = 5 gallons more!!
  4. Possible Corolla brake problem
  5. Removing the air vents?
  6. OME Shocks specification
  7. Spider Gears: Is This Normal?
  8. Anyone got problems with window defrosters?
  9. Heater not working!!
  10. Yotatech wall poster on Car Town
  11. wiring nightmare for newbie
  12. SC and catalytic convertors
  13. Truck wont start after changing head gasket
  14. Fart can exhaust
  15. My truck is eating batteries!
  16. card board in front of the radiator
  17. Need a Transmission: Marlin Crawler vs. Man-Trans
  18. Cylinder Head to Timing Chain cover bolt is stripped.
  19. Trail gear skid plate and Allpro E brake
  20. BG Products oil change experiment.
  21. who's truck is this? looking for specs
  22. Found A 72' Hilux
  23. Finally upgraded
  24. Beware 'o floppy bug shields!
  25. Android Smartphone OBD II reader - anybody use Torque Pro?
  26. Belt splitting down the middle
  27. Post Pics of your 22RE Turbo Setup
  28. Rather sudden loss of fuel economy, 89 22re
  29. 3vze temp gauge sensor
  30. I am trying to determine what trans this is ?
  31. I've never seen one of these before....
  32. toyota 4 runner rear end
  33. 22R in Peril
  34. John R leaf springs
  35. VSC, VSC off lights
  36. Another Clutch Master Question
  37. Welding Proceedure Help PLEASE!!!
  38. EFI fuel pump bracket different between 4runner and pickup?
  39. May have to get rid of my yota
  40. 1990 TOYOTA 4RUNNER Steering Gear
  41. a340 transfer questions
  42. Toyotas in warzones
  43. Where to buy brass tube nuts.
  44. Military Tan 4runners?
  45. Looking for good '80's dash repair materials
  46. 1990 4runner v6.. power windows and heater motor doesnt work..
  47. Boycott Automotion
  48. 3.4L rough start when cold w/white smoke (sometimes).
  49. trading my 89 in on something new(er), need advice
  50. Budget expedition truck - 2nd gen 4runner vs 60 series LC vs 80 series LC
  51. How good is the 2.7L?
  52. Just traded my Jeep
  53. Anyone remove the rear drive shaft and drive in 4HI to break in a front Diff?
  54. Brake pedal problem
  55. Yota Swap Month
  56. Por15 (How does it hold up long term?)
  57. Any good literature on seting up gears?
  58. Pomona off road expo pics
  59. Best roll-on bedliner?
  60. Spool locker questions
  61. 5 speed a bit 'bitey'
  62. Model codes
  63. Crappy Rattling
  64. Trying to make a decision...
  65. electric fuel pump
  66. 1993 Pickup Odometer Issue
  67. Just picked up my first yota.
  68. Pedal Assembly
  69. Pull the head?
  70. 44 or 42 on toyota axles
  71. 88/89 trucks
  72. Power Steering Pump/Pulley
  73. OEM Original Engine Management?
  74. finding a new home
  75. only a 22r would run like this
  76. weber carb info
  77. Some Photo Shop Assistance Needed
  78. TN members: Anyone familiar with the state's Antique Auto Tags?
  79. 20R in 1992 pickup
  80. I wanted to go to the darkside...but it wouldn't match my purse
  81. whats your top speed
  82. 22re mid range cam valve adjustment
  83. Rear axle bearing play- how much is too much?
  84. New truck
  85. how built is your 22r?
  86. Another New (to me) Truck Box
  87. to build or not to build? a moral dilemma...kinda.
  88. help me identify my 22r year
  89. Hilux Surf Overheating
  90. Vacuum, Electrical, Shop Manuals: PDF's for many vehicles!
  91. Wrecked/rolled my '98 4runner
  92. Keyed power...underhood source...
  93. Best transmission fluid advice I've seen
  94. TJM back in the US!
  95. What aftermarket gauges do you guys have?
  96. Toyota Parts Zone doing away with part diagrams?
  97. 22re haul a snowmobile?
  98. Couple electrical related questions 94 PU
  99. Power antenna
  100. Self-Painting Your Rig, Good Primer?
  101. Radiator Flush/ Coolant Disposal
  102. oil change interval v.s mileage
  103. Interior door panels 84' pickup
  104. Another Opinion Thread - Paint Colors
  105. My DIY 20r Port & Polish! (Pic Heavy)
  106. New Truck Box
  107. Online parts diagram w/ breakdown, part numbers, & pricing
  108. Coolant Question ?
  109. Interior Carpet Replacement with Bedliner Think Tank
  110. Opinions on stripes and wheels
  111. Plastic fuel tanks?
  112. Wheel spacer questions
  113. Which is Cold idle/wam idle (Pic included)
  114. 86 22r gear ratio
  115. Transmission Question... Need HELP!
  116. will a 1987 4runner body mount easily to a 1981 pickup?
  117. Hub bearing preload, lbs or ft/lbs?
  118. Toyota Owners of Eastern Idaho (Rexburg/Idaho Falls Area)
  119. getting a title for angus?
  120. Overheating after driving without ECT
  121. cab swap/frame swap. wich title to use?
  122. Help decoding a VIN plate
  123. Weird Starter Issue
  124. Starting a vehicle thats been sitting for years
  125. any encounters with this camo?
  126. Repair Guides For Most Toyotas
  127. River Crossing Vid...
  128. Thank you Mr Nut-Cooler designer guy!!
  129. color previews
  130. Other Yotatechers Maintenance Preferences Info
  131. another toy 4Runner! (1gen)
  132. lift shackles didnt lift
  133. Truck Tow hitch on a 4Runner?
  134. Lincoln locker on pavement?
  135. This site has some great info
  136. What does your engine bay look like?
  137. Who runs Synthetic motor oil?
  138. Sacramento Area Junk Yards
  139. To My Surprise!!
  140. what color to paint my shift selectors?
  141. Using Cardboard to Fiberglass?
  142. Question for anyone who has removed a cab.
  143. Throwout bearing or clutch chatter
  144. AIR SHOCKS or Boots
  145. 3vz "isr mod" design modification questions.
  146. original panels: to cut or not to cut, that is the Q
  147. 22RE ARP Head Studs Too Long? (Pics)
  148. 4WD Toyota Owner Magazine - why aren't you a subscriber?
  149. Tmperature Switch #2
  150. Is this driveshaft put together right? (pic)
  151. How to remove factory under coating?
  152. EPC diagrams help?
  153. Ideas for an underbody tool box, 1st gen runner
  154. I'm thinking about getting a trainhorn installed on my car. Suggestions?
  155. Towing 97 4Runner
  156. Sources for Replacement Weatherstripping/Door Seals?
  157. 94 PU or 86 4 runner?
  158. Fuel tank sealer
  159. Transfer case or transmission?
  160. Diesel for the Taco
  161. leaf spring pic!!
  162. lost key any advice?
  163. Snorkel head, pre filter or the "open" type?
  164. Toyota Axle Help
  165. About to drive 1200 miles from CA to NM. Any Tips?
  166. Mystery Part Idenify Thread: Toyota What?
  167. Radio has backlights, but doesn't turn on
  168. Block torn down - fix compression?
  169. Best Upgrades/Maint while waiting with stripped block?
  170. next new Tacoma???
  171. Junk Yard Ripping me off?
  172. Coating a frame with por-15...wich por-15 product to use?
  173. Oil filter ??
  174. KM2 Tread Depth
  175. Just another "help me identify these wheels" thread...
  176. Has anyone heard about these seat covers?
  177. Finish Clouding? Dent Removal?
  178. How to get a pitman arm off without using a puller
  179. spare tire mounting
  180. Funny Security System Story
  181. Wreck with a 3" body lift
  182. Your Toyota
  183. Can someone please tell me the difference between these two threads
  184. sounds like there's a kitten in my 22R *vid*
  185. How much Herculiner for hood and 97 Limited trim
  186. Poor Rock Oil Pump Casting
  187. Any (north) Baltimore Area Pick Your Own Part Junk Yards?
  188. 2WD to 4WD conversion, brake question
  189. Toyota USA to Have Greater Design Control
  190. Dumb question about proper tire pressure in aftermarket tires
  191. Debadging 4Runner, Paint Touch-Up and Pinstripe Removal?
  192. Wont start after changing EGR HELP!!!!!
  193. need solid axle length measurments
  194. 54mm nuts keep coming loose on SAS
  195. Stripped Head Bolts HELICOIL TIME
  196. Stock replacement steering damper
  197. Help me diagnose this issue
  198. Will not shift into gear.
  199. Name That Roof Rack!
  200. Best way to drain a power steering pump.
  201. rear axle housing question
  202. Dirty Throttle Body
  203. Can oil pump go bad?
  204. Compliments on your truck/4runner
  205. Advanced Auto Parts online code $40 off $100 - ship or pickup in store
  206. Fuel Lines
  207. fix or replace
  208. Hot Dip Galvanising
  209. Graveyard finds...Post the up! Pics inside!
  210. Whats your worst wheeling experience...
  211. My Rav4 L
  212. Under Cab/Bed Paint/Liner
  213. Anybody know about rebuilt 22re's in kannapolis NC?
  214. How to test fuel pressure regulator?
  215. 22R Alternator Adjustment Bolt Size?
  216. Engine Swap 92 Pickup
  217. 22R - does this noisy timing chain look ok? (pics/vid)
  218. Shock Stiffness
  219. What you hate most about your Toyota
  220. trans temp guage sensor?
  221. Anyone ever seen or had a galvanized axle housing?
  222. Toyotas in commercials
  223. pilot bearing
  224. Alaska: Cold weather Car prep advice
  225. Importing vehicles from South America
  226. Hydrogen power???
  227. Header info?
  228. opinions on handheld scanners/code readers?
  229. ELocker gear Paint mark advise
  230. 22r Carb - Another frustration thread
  231. jerry can
  232. Poor bumper...
  233. MAF postion in relation to TB
  234. Bad day for the 4runner (AKA dogs, door dings and dumb people)
  235. name this header ?
  236. Semi-OT: Seafoam to treat fuel cans?
  237. Necessary to put on stands?
  238. Rear tire swing?
  239. WeRock Aetna Offroad Club (TN)
  240. what kind of oil are you guys running?
  241. colored bed linder in rattle cans.........colors other than blcak...Where?
  242. Unmetered air?
  243. Toyota Turbo emblems (HELP!)
  244. Highlander Suspension
  245. Geez i miss my truck
  246. Brand New XM Onyx for $19.99
  247. Mobil 1 vs O'Rielly synthetic
  248. 22RE polyurethane engine mounts
  249. Tow Capicity on Marlin Crawler rear bumper
  250. where to buy a carbd 22r?
