- R.I.P. NCTTORA FSMs
- new to Toyota need advice
- 87 toyota doors?
- cup holders in first gen 4runner and second gen trucks
- speedometer help...not working at slow speeds
- 4Runner might be dead...thinking about a RAV4
- Hard to find parts-why does no one make them
- Lift Kits and Exhausts
- Question about roll on paint
- gray vertigo backseat? 85 4runner
- i hate new england some times!! rust!!!
- Only one selectable front locker?
- Long Term Engine storage--options?
- innova obd2 scanners,any experiences?
- Need some advice from the old and wise
- Is there a remote or cable shifter for an RF1A
- Actually a Camry Question
- Does anyone regret deleting the EGR?
- Insure or register a newly bought vehicle before driving it home from another state?
- winchs
- Off-Road driving and Camper shell/ Truck Cap Integrity?
- Toyota fiberglass hood scoop
- which is better for trunnion bearing replacement
- The door locks! boot up the door locks! (bad door locks)
- Toyota parts shipped internationally?
- Center console help!!??
- Parts that are best replaced with Toyota OEM parts.
- Multiyear interchangeable OEM parts for exact swap, or mod purposes. Anything goes.
- 87 door hinges
- Dyno Test
- Extra Cab Cargo Shelf Build
- Best "outside of the box" trail fix?
- wheel bearing load? 4x4 cv removal
- 4 bad alternators in a row please help
- Replacing motor mounts
- Leak on rear axle but from what???
- Diagnosis: What noise is this?
- Bestop supertop on 2nd gen pickup
- My Police Spotlight
- two 3rd gen equal one... easier to move?
- sfa knuckle alignment/trunnion bearing replacement
- Cleaning an alternator
- Suntop Softtop Pricing
- Removing Spray Paint Coats
- Rear diff bolt gone
- Stumped on repairs
- Bringing the yoter back to life, need to find a truck bed camper (WINNEBAGO)
- LPS3 Undercoat
- OBD1 Scanner Recommendation(s)?
- T100
- If a clutch is chattering, will it need to be replaced soon?
- Don't Be Jealous
- Undercarriage Rust/Dirt
- dual fuel propane / gas for 22re theory, give me your thoughts
- Tow package on a limited
- When did they change engines ?.
- Model Year vs. Production Month?
- debating a land cruiser 80 or 4runner..
- Toyota Mobile Website - vehicle specs etc
- Benchseat identification and seatcover help
- Aesthetic Help
- Tip on Hydro Assist Install / Bleeding
- 84-86 Aluminum side mirrors?
- Toyota Pickup Check Engine Light
- Help w/ 1996 Camry
- 16 x 7 Steelies
- engine preluber build ideas
- A/C Leaks water into cab
- diesel running issues after sitting for a year
- Easy to build fishing rod rack
- Something SO simple! Spark plug gap. A heads up.
- Hello Everyone
- Rear main seal backing plate thread repair
- Help me prove my Aunt wrong
- key went missing for truck box so wat do i do now???
- Condenser Fan Operation Question.
- weber 38...just for the record
- What are ideal spare parts to carry?
- Trucks getting old might be time for a new girlfriend.
- K&N reusable washable SS oil filter
- '88 6cyl 4Runner AT almost nothing from any gear...
- broken smittybilt winch
- OK, what the heck is this stuff caked on my wheel wells (road construction-related??)
- school me on gear lube?
- Would you use this rusty diff?
- 22re vs. 3rz...for college
- Moonshine gas, not good for our old Toyotas.
- Starting issue! Ignitor has no voltage....
- Buying my first 4runner - good deal?
- Insulating tape on heater core
- When buying a used rig - problems to look for?
- Towing a Celica with a 22RE 4Runner auto, can it be done?
- 97 runner has a whine in the rearend
- Differential gurus, may I pick your brains?
- Remember to check on your suspension/steering components!
- Intermittent Overheating?
- Some information for people who want a SOFT ride
- Seat interchanges
- Fair Price?
- '86 stock Runner-oil pan removal question
- Emergency Redneck Diff Locker!
- 96 sr-5 tacoma power mirrors
- Bilstein's for a T100?
- Sputtering after oil change??
- Body Wrap on a 4x4: Good or Bad Idea?
- Can someone help identify these wheels 15x10 6x5.5
- What Toy Tech lift should I get? 1995 4runner
- *NEW* Gear Oil Specific RTV
- What does your Yota weigh?
- Rust on powdercoated sliders
- R151F 70% stronger tranny than stock
- Coolest sticker on the planet!!!!!
- Best off road wax?
- New RAV4 - Thoughts?
- Random Misfire
- Questions for those who have rhino/line-x'd their interior floors
- At what time horizon would you justify the expense of regearing twice?
- Cooling issues
- Have you ever seen.....85 IFS truck
- Marlin crawler shifter ball seat question
- WOO HOO! Just scored a free arc welder and a bunch of steel!
- Catching Rust Early - Now What?
- front locker or rear locker?
- how to convert a 6 lug axle to 5 lug
- Daily Driver Buildup?
- shaking problem when on the highway for a few minutes, then goes away
- When to throw in the towel?? IE: finally get rid of your truck
- Duplicolor (interior painting)
- 22re problem
- CT20 turbo info please
- Toyota Adhesive & Sealant Cross Reference Chart
- confused on replacing the steering stabilizer
- 22r from MO to CO
- help with parts search please.
- FJ62 rotors vs V6 IFS Rotors?
- Fan Clutch Failing?
- Toyota Says I Need An Induction Service?
- Seat covers
- Line-X Finish results
- /Body work what next question
- permatex RTV sealant
- The Supercharger
- worth it? 89 reg cab 5 speed 3.0
- ANOTHER ZUK mod thread......Before & after
- Aftermarket spring perch question
- transfer case help
- L43 to w50 tranny swap questions
- Susp. Lift - Rotate Rear Axle?
- 02 highlander
- 22RE Rough start, fuel pressure regulator?
- N-Fab style nerf bars
- 91 22re advice
- Power outlet on Tacoma
- Official Toyota Memorabilia thread
- 3VZ High Temp on Freeway?
- Your opinion on OEM vs. Aftermarket parts please.
- How To Change Your Clock Color!
- For All You Canadian Yotas
- 22r block (pre85) in a 85 22re?
- Picture requests. 88 xtra cab and 85 regular cab
- Strange Vibration & Possible Sparkage...?
- V6 thirds, aussie. Best oil to run? Synthetic?
- Tundra 3.4 vs. 4.7
- Car won't go into drive but reverse works flawlessly
- any negative experience with firestone lifetime alignment?
- 22rte: too small a turbo?
- Does anybody know of some good salvage yards in the Southeast, mostly Toyota?
- Purolater Oil Filters
- Doctor Injector
- Anyone Line-X an entire truck body?
- Had to share
- toyota truck question
- What is this skid plate from?
- Just cool!
- Rear heater switch amp rating
- stainless steel brake hoses
- 1988 Toyota pick up having issues with the fuel tank
- Autozone/O'reilly Radiator Warning
- Where's your Toyota from?
- NW Washington Salvage Yards??
- Air suction in the gas tank resolut probleme !
- crazy stuff done in crazy places
- Whats your opinions/ thoughts on wheel spacers?pics?
- getting rear window back on tracks
- New vs. Old(er)
- 1985 rear sliding window trim and other window trim where to find
- Serpentine?
- DPF Removal
- Curious if you guys think I'll make it
- NEED SOME IDEAS Please.....
- Help! Urget! Stuck on side of road. Electrical
- Should I try to adjust my coilovers? Rust...
- Rusted out frame: the Saga and the Project
- Misfire cylinder#2 has me stumped!!!
- Supercharger
- FIPK Mount breaking - suggestions?
- Body Panels interchangeable?
- Thread Adapter
- Tow bar with Marlin bumper
- Misfire on ALL 6 cylinders?
- Changing front E-brake cable
- "Custom" Seat Covers
- Overhead console?
- RC4WD 1st Gen Crawler
- First Gen Vs. Second Gen
- Good oil article.
- To chisel or not to chisel???
- Minimum Specs for Compressor to Spray Paint
- toyota to denso part # conversion?
- What do you use your yota for? :-)
- little 1980's first test run today
- cold weather help, power steering issue
- CB Radio question!
- I will never go to a junk yard again.
- Stalking a Yota you see on the road.
- Post your timing specs
- Sighting: Built FJ60/62? running around NE Fremont in Portland, OR?
- Seats for 86 Standard cab
- Offroad Solutions Accepting Orders?
- installing a headliner
- who likes the mud and where yall at???
- wheres all the mudders????
- Help, I want to put a snorkel on my sidedrafts.
- Farmers Insurance price on my truck
- Urgent help needed truck wont crank
- 200k plus poll.
- 2002 highlander codes issues
- Highlander tow package
- violent shaking in gear and neutral
- 85 Pick up gas tank: alternate mounting ideas
- 4WD engagement issues
- a/c compressor into air pump
- Issues with CV axle replacement
- Help!!12mpg and errror code 25& 26
- CV Joint Question (1986 Toyota 4Runner)
- Seafoam: Before & After Pictures!!!
- Hey guys im back finally got a question
- Incorrectly installed exhaust tailpipe?
- 83 vs 84/85 Front Axle
- Next vehicle, looking for advice from ya'll.
- Bleeding power steering
- Show off your Toyota BUG OUT VEHICLE! (definition inside)
- Chrome...?
- Limited slip diff id please ?
- Okay to use RTV on top of gaskets?
- Valve noise after getting stuck on steep hill
- 350 swap Questions
- Whaou buying your yota for christmas this year?!?!!t are y
- Anyone got pics of their spider gears?
- How many times can I replace this Napa junk
