Lincoln locker on pavement?
I've recently been looking for a first generation 4Runner to use as a daily driver with off-road capability, and I think I've found one, but there's a catch- the truck is currently equipped with a Lincoln locked rear end, and it's located about 90 miles away. I've researched swapping out the 3rd member for an open diff, and I'm confident I can do the work, but I'd much rather do it at my house.
My question is this- Am I setting myself up for either a horrible drive or risking significant damage to the truck by driving it home on a locked rear hub? So far the price is right, but I'm afraid I might cause damage to the axles, tires, etc in one short drive.
My apologies if this has been asked before- I searched and couldn't find anything else...
Thanks!
Thanks!
you wont damage anything. my friend drives all over the place with his lincoln locker, it just chirps the tires when making sharp turns. you will be fine for the drive home.
all automatic lockers will chirp tires on pavement and occasionally make a "clunk" noise if you play with the clutch. i suggest going with a selectable if you dont have a clutch.
My concern is that it's not an automatic locker, but that's it's permanently locked- basically a spool.
what he said, you wont even know its there on the freeway, only slow around tight turns is where you will hear it chirp the tires. drive it home see how it feels you may just want to keep it in there. only down side to that welded locker is might wear the tires a little faster.
just keep it and get used to it you will appreciate the added traction... I ran a wleded rear in my truck before and barely ever noticed it except tight turns I would do it again
Like others have said you'll be fine on the drive home. You might want to drive it around for a while and see if you can handle the slight chirping around corners, most folks forget that the rear is locked after a few days of driving so you might want to just keep it locked for the added traction while wheeling.
Oh and if you do decide to replace the rear with an open diff then at least go off road with it still lincoln locked once or twice. You'll probably change your mind once you find out how nice it is to have it locked.
TheBFA
02-15-2020 06:55 AM
83yotastockR
11
11-10-2015 06:54 AM
Odin
09-26-2015 06:56 PM
Toys4parts
09-26-2015 01:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
