PDA
View Full Version : General Vehicle Related Topics (Non Year Related)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26]
  1. Wrecked my Truck (photos)
  2. ? Valve Train Noise
  3. Pull PCV and Truck Dies
  4. CA legal headers for 22RE?
  5. MPG vs. GPH
  6. Engine dying?
  7. Auto X-ray on sale at GI Joes
  8. Solution to locking keys in your truck
  9. Important Lift Question
  10. shells peeling
  11. Mudding
  12. Clear corner lenses
  13. Could this be the torque converter?
  14. Tire Size Odometer change, need math Wizard!
  15. looking for a yota clinometer
  16. 5spd tranny slips out of gear when parked on a hillside
  17. Where to buy 1/8" wheel spacers
  18. Rusty Brake Rotors
  19. Documentation of repairs.
  20. New to the forum and Toyota's. (pics)
  21. need help- A pillar for tach install ?
  22. gas quality (searched)
  23. Suspension questions
  24. For sale: my rig
  25. how many times can i go in water
  26. Dumb question on Optima 34/78
  27. BR-3 OBDII scanner and Palm support
  28. Lets see the "artsy" pictures of your rigs..
  29. picking a locker????
  30. Consumer Reports (toyota 3.0 prone to engine sludge)
  31. Refinishing SR5 Alloy/Chrome rims
  32. Which Hi-Lift?
  33. Need advice: White smoke and "knocking"
  34. high flow cat.
  35. 33x12.5's on a 7" rim?
  36. Toyota Electronic Parts Catalog (EPC)
  37. quality of shackles?
  38. 75w-90 vs 80w-90
  39. surco mounting
  40. Wrecked 4Runner...dangit.
  41. spark plug electrodes broken off in engine.
  42. Best performance filter on the market? True Flow?
  43. Driving with no spare?
  44. 33x10.5x16 is what in metric
  45. thule bar height question
  46. Fluid Weights
  47. Please state your thread topic! Ambigious thread titles will be deleted w/o notice
  48. More Engine Woes!
  49. 3vzFe valvetrain noise
  50. Black 15x8 alloys?
  51. Slightly larger tires?
  52. Anyone running these racks?
  53. Tranny to transfer leak???
  54. group buy for Donahoe coil overs?
  55. Radiator Issues
  56. speed in water
  57. Help with cold starting
  58. Brakes..... How to?
  59. Fluttering sound when cold
  60. Sqeuaky Steering
  61. Portland Yotatechies!
  62. 99 4Runner Leaky Rims
  63. Where to find Optima height adapters?
  64. Which wheels ?
  65. ARB Bumper Owners!?
  66. flares for trimmed fenders
  67. Need help dianosing a problem
  68. Anyone know a good place to pick up center caps for cheap?
  69. Third memeber issues
  70. What do you think of these ebay tires....
  71. power steering fluid help
  72. 2wd t100 spuspension lift
  73. Steel or aluminum wheels?
  74. Hubs locked and vibration questions!
  75. removing super gluhade from dash
  76. best toyota engine?
  77. Questions about different color RTV
  78. oil cooler??
  79. Clack Clack Clack Clack
  80. body work and painting
  81. In case you are interested....
  82. Has Anyone Had There Ecm Rebuilt?
  83. Expedition-style travel
  84. kill all tow truck operators (woot, water pump fixed though!)
  85. Quick 2nd gen help... grommets in firewall ?
  86. Include spare in rotation
  87. How do you tear down the outer CV joint?
  88. Landcruiser wheels
  89. Yotatech 2006 Calendar is ready!!
  90. Coolant Flush
  91. tips for leaving truck park for 4 years...
  92. Cheaper than Trueflow
  93. Is it worth it... Synthetic and Iridium Plugs
  94. why is it bad to replace ATF.??
  95. 4wd transfer-case Up-keep maintenance
  96. Tranny input and output seals???
  97. Japanese-built 4Runner versus U.S.-built Tacoma
  98. Gear Oils
  99. TRD shifter group buy sign up thread
  100. Cloths for cleaning interior
  101. The calendar will be delayed...
  102. precision engine rebuilders
  103. Mobile 1 Synthetic Oils
  104. VIAIR 400P - $229.69 @ Summit Racing
  105. Cheapest place to order Toyota service manual other than ebay?
  106. What is the most offroad capable 4runner ever produced?
  107. Oil filter for 3.4 and 22RE are the same?!?
  108. Will the height adjustment of the clutch pedal affect the wear of the clutch?
  109. when to change battery?
  110. The worst thing that can happen to you and your car
  111. Machine Rotors and Replacing Front Pads
  112. Need Body Work Advice - Bondo, Kitty Hair and Fillers
  113. Bad Connecting Rod
  114. Window Chalk
  115. Undercoating
  116. True Flow air filter
  117. Transmission fluid change and the torque converter??
  118. difference between transmission flush VS fluid change?
  119. coolant drain vs flush
  120. Who has the most bad a$$ 4Runner here? picture proof!
  121. Month long vacation, how to store Runner?
  122. Hub getting hot
  123. Meguiar's NXT wax rules!
  124. looking for retaining washers
  125. Consumer Reports tire test '05
  126. Need some pointers/advice... selling my 4th gen for a 3rd.
  127. Door - service hole cover
  128. Seafoam Verdict
  129. Clutch Master Cyclinder
  130. Pine Tar Pitch removal?
  131. 3M Rubbing Compound
  132. engine stumbling
  133. tranny/diff/t-case oil...synthetic?
  134. Door won't open from the outside!
  135. New member and tire/wheel question
  136. Build up
  137. keeping chassis rubber in good condition
  138. stripped and spinning bolts
  139. Removing front windshield molding tips
  140. Pentosin Antifreeze
  141. Using old oil for oil spraying undercarriage/rust proofing?
  142. need help! CV boot fitment
  143. Positive camber?
  144. Blue smoke coming out of exhaust?
  145. Ever tired of wrenching on your Toyota?
  146. Yotatech calender contest #2
  147. Pin stripe removal tool INFO needed.
  148. Brake Maintenance info needed.
  149. new ignition
  150. Whats the next mod for you truck?
  151. Toyota Type T-IV auto tranny fluid equivalent?
  152. Engine Codes
  153. new diff....rtv sealant?
  154. How do you measure exhaust pipes diamater.. I.D. or O.D?
  155. clutch play problem?
  156. Starting problems when HOT and COLD
  157. Transfer case skid plate giveaway in the vendor section.
  158. Mobil1 5W-30 dino oil
  159. the pleasure and pain of maintenance
  160. can-back soft top
  161. The best way to buff out a paint scratch?
  162. Got the rig professionally waxed/buffed
  163. Thing you found out AFTER you owned your 4Runner for a while.
  164. $600 CUSTOM rear bumper for 2nd & 3rd gen!
  165. 2 pinion or a 4 pinion gearing?
  166. transfer case output flange and bearing
  167. Clutch replacement, ceramic or other?
  168. Dreaded Check Engine Light
  169. HOw do you secure your ride???
  170. How are these prices for major tune up????
  171. Show us your best cheap mods!
  172. how to bleed bleeding rear brakes
  173. MEGAWARRIOR or LOADWARRIOR??? (poll)
  174. Seafoam Rocks!!!
  175. Homemade Body Lift...
  176. So who's subscribing?
  177. Cutting pipe off after muffler.
  178. Lockright Locker vs Lockright no-slip
  179. Rust bullet or POR15 ???
  180. Mobil Synthetic - HIgh Mileage
  181. Do you gap your plugs?
  182. Holy Cow! 4x4 toyota RV!
  183. Black wheels...
  184. Chinese 2nd Gen based truck
  185. What exhaust do you think is LOUDEST?
  186. what does your rig weigh
  187. ??? on 3M clear bra
  188. c&d comparison test
  189. Good news about our runners...
  190. Flushing Brake System
  191. What Amsoil grease should I use for my driveshaft ?
  192. 3.0L to 3.4L Swap QuestionS
  193. How many lights?
  194. 4-Runner Vs. Landcruiser
  195. Anyone ordered from RallyLights.com?
  196. bilstein shocks
  197. What is your favorite 4runner body style?
  198. Mr. Alternator??
  199. Transmission Temperature Guage?
  200. Time for a Transmission Cooler?
  201. Panhard bracket: drop or lift?
  202. M/T Tire Poll/Comments
  203. Toyota Maintenace Search Engine, Online FSM Manuals and Hunter Balancers
  204. Are U satisfied with your aux. lighting??
  205. TRD stickers
  206. Kartek...
  207. Show us your clean runner!
  208. Seafoam Injector / Intake Cleaner = GOOD STUFF
  209. oil filter poll
  210. Tacoma frames weaker??
  211. List of Toyotas that has passed your hands.
  212. who has the most miles?
  213. 96-02 and +03 4Runner owners... Custom door sills
  214. How many miles do you go between oil changes?
  215. Extremeair/ARB locker install has started (need help)
  216. What do you guys think of these wheels?
  217. What is broken on YOUR Toyota
  218. $10 Snorkel System
  219. weathertech mats
  220. Stumble at 1500 RPM
  221. Gear Oil vs. "Hypoid" Gear Oil
  222. Hi-Lift Jack & Amsteel Blue Whinch Rope
  223. Mixing tire brands, is it ok?
  224. Dual batteries under the hood
  225. Sound deading project 1/2 way done- pics and impressions
  226. Ice cream in the desert
  227. Fuel Injector Cleaner
  228. What mod would you do, if you could only do one?
  229. Bumper Vs. Brush Guard
  230. 5-speed or Automatic: which one do you have?
  231. Change to synthetic oil on high miles truck
  232. Would you buy a diesel?
  233. Which air filter?
  234. Poll: What generation 4runner do you own?
  235. How many miles does everyone have?
  236. The Turd turns 200!
  237. Max miles on a 4Runner
  238. Differential gear lube oil... synthetic or not?
  239. How many of you use torque wrenchs?
  240. Best way to clean engine?
  241. Interesting water storage device
  242. Yet another painting question
  243. Chamosis or wringer
  244. Squeaky doors
  245. pvc pipe rod rack mounting
