Using old oil for oil spraying undercarriage/rust proofing?
Old Sep 21, 2005 | 05:16 AM
4Hummer's Avatar
Over the past year I have accumulated 2 big pails full of used oil, (Engine oil, gear oil, and whatever else is in the bucket)
Is it feasible to re-use this oil for oil spraying the undercarriage of my truck? I'd run the oil threw a filter first, and than spray it on in my driveway (I have a gravel driveway)
Pros? Cons?
Old Sep 21, 2005 | 05:39 AM
MTL_4runner's Avatar
Is this for rust proofing or for mudding?
I don't think there are too many minuses for doing that as long as you don't get any on the ground.
Use a tarp or something to be sure you contain any spills or runoff and let sit overnight.
I personally wouldn't do it because there are other better, more effective alternatives out there.
EDIT: Here is another link I found on this (says not recommended):
http://www.detnews.com/2004/autoscon...g03-192066.htm
Old Sep 21, 2005 | 06:55 AM
4Hummer's Avatar
I don't think there are too many minuses for doing that as long as you don't get too much on the ground.
Both I guess. Rust proof the undercarragie and maybe spray it into the doors and quarters.
Old Sep 21, 2005 | 08:18 AM
Glenn's Avatar
I wouldn't spray used oil on the driveway. Too many toxins will taint any groundwater. Besides it may be illegal.
Old Sep 21, 2005 | 08:23 AM
dlbrunner's Avatar
That would be illeagal in the U.S. Used oil may contain Dioxin, and also petroleum is a KNOWN cancer causing agent. If you are comfortable spraying a carcinogen onto your driveway I say go for it.
Old Sep 21, 2005 | 06:29 PM
kyle_22r's Avatar
why the heck would i want MORE oil under my truck?
Old Sep 21, 2005 | 09:13 PM
DudeBud's Avatar
call the EPA and tell then what you are going to do first
Old Sep 21, 2005 | 09:23 PM
4Crawler's Avatar
I've heard of folks using an old garden sprayer to oil down the inside and outside of their frames periodically for rust prevention. Supposed to work fairly well, albeit a bit messy.
I know here in the states, using engine oil for dust control is not allowed anymore. Down near a gold mine we drive past near Death Valley NP, they oil the road with a biodegradeable mix of water and used vegetable oil. Smells a lot like french fries going down that stretch of road. One time we got caught behind the oil truck and our rigs literally had an inch of oily mud plastered all over. Dreaded the thought of having to wash that off. That night in camp, it rained and the next morning, the rigs were spotless, that oil/mud mix just washed right off in the rain.
Old Sep 21, 2005 | 10:12 PM
Albuquerque Jim's Avatar
When I grew up in PA I knew of a garage that used a mixture of used oil and acetone for rust proofing. They sprayed it through an old paint sprayer on the undercarrage. It works pretty darn well.
Old Sep 22, 2005 | 05:25 AM
The EPA is in the US, he is in Canada.
Old Sep 22, 2005 | 09:49 AM
DudeBud's Avatar
doesnt canada have some sort of EPA
Old Sep 22, 2005 | 10:01 AM
X-AWDriver's Avatar
Just because he's Canadian still might not make it a good idea to expose himself and others to a possible health hazard.
Old Sep 22, 2005 | 10:03 AM
Most provinces have a department of environment but there is also a federal version as well.
The provincial would be the one to contact because environmental laws may vary by province.
While I doubt anyone would come and fine you for doing it, it ranks about the same as pulling off your catalytic converter.
The term "EPA" is specifically a US agency.
Old Sep 22, 2005 | 10:10 AM
Yota4runner's Avatar
umm kay? Just because he is Canadian..? The way you worded that entire sentence sounds bad..to me anyway.
I think if he takes the proper percautions in doing it, (laying down a tarp, etcc...) I think it would be fine.
Old Sep 22, 2005 | 12:59 PM
4Hummer's Avatar
To clear a few things up. First off I would put down a painters tarp to catch all the oil, (The reason I said I have a gravel driveway was for the over spray and stuff... Its not like I was going to dump the oil onto the gravel guys)
My thoughts where this. Filter the used oil to get any large particals and dirt out, Load the oil into an old paint sprayer and coat the undercarrage, inner doors, fenders, and rockers, let it sit for a few hours and clean up the mess.
this beats paying $95 for an oil spray at the local place.
I can't see how this would be differant than getting a professional oil spray other then the fact its used oil, and I would be doing it myself.
As for the used oil being toxic and cancer causing I will look into that a little further. but other than that so for it seems like it will work ?
thanks for the info so far guys.
Old Sep 23, 2005 | 11:36 AM
X-AWDriver's Avatar
I was referring to the comment about Canada not having as many restrictive laws as the EPA has here but yeah,I look down on Canadians anyway cause they're sooo different than us.
chukarhunt
Dec 8, 2019 11:39 AM
calderp
Jul 27, 2015 09:58 AM
britishdudes2dr
Jul 25, 2015 06:47 AM
HookahRoo
Jul 20, 2015 07:06 PM
HRDC0R19
Jul 5, 2015 06:43 PM
