difference between transmission flush VS fluid change?
Old Oct 31, 2005 | 12:15 PM
Grounded's Avatar
Is there a difference between a transmission flush, and a fluid change? The saleseman suggested it might be a good idea to give the tranny a flush every 50,000 km.
Is there anything else above and beyond one can do to maintain a transmission?
Last edited by rocket; Feb 12, 2011 at 09:51 PM. Reason: reflect information for searching
Old Oct 31, 2005 | 12:32 PM
snap-on's Avatar
i would call a fluid change ... pull the drain plug, let it drain, fill it back up.
a flush would imply that you changed more than just the fluid in the pan, meaning you pumped/flushed out the cooler(if it has one) and the torque converter.
Old Oct 31, 2005 | 12:34 PM
ebelen1's Avatar
Originally Posted by Grounded
Is there a difference between a transmission flush, and a fluid change? The saleseman that sold me a used Honda Accord suggested it might be a good idea to give the tranny a flush every 50,000 km.
My understanding is a flush gets all the tranny fluid out. Your truck would be hooked up to a machine that gets tranny fluid out of the torque converter.
The fluid change is where the drop the pan, remove the old fluid, clean the pan, and then refill. This way, there is still some old fluid in the torque converter but not much. Theory has it that if you change regularly, this would be a good way to go.
If you have a ton of miles and the fluid has not been changed, people have claimed that flushing the system could cause more damage than good, assuming your tranny fluid is burnt.
If you're asking for a truck, go with a tranny cooler. For an Accord, the fluid change should be sufficient.
Old Oct 31, 2005 | 02:03 PM
Grounded's Avatar
Thanks for the input! I just found the answer to my question posted Oct. 29th.
Old Nov 1, 2005 | 05:03 AM
mt_goat's Avatar
Here is the best info I've found on the subject: http://www.gadgetonline.com/TransFlush.htm
Old Nov 1, 2005 | 07:57 PM
Grounded's Avatar
THANKS MT Goat for the info! I agree, this article is very well written. I'm feeling pretty confident now about checking out my transmission fluid tomorrow.
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
