PDA
View Full Version : General Vehicle Related Topics (Non Year Related)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26
  1. if you had 12-14k to spend on a 4runner...
  2. Considering buying a 4runner
  3. Where do you get a 2 1/8" socket?
  4. Can you buy replacement skins for a 94 toyota bed?
  5. Help with 96 T100 ABS
  6. Where to mount ARB compressor?
  7. Bob is the oil guy!
  8. what is your preferred Gear Lube? Anyone ever hear of Lubrication Engineers, Inc.?
  9. I am LOCKED! Lock Right. 1st on-road impression.
  10. witch winch should i get?
  11. off road wheels
  12. Best filter for max engine life
  13. 4runner versus Jeep Wrangler?
  14. Surco Safari Roof Rack
  15. What weight oil?
  16. need tires, where should i go?
  17. What are the effects of RUST?
  18. Timing question? no more sticker under my hood.
  19. NEED Reverse/BackUp Switch HELP
  20. Cool shock
  21. Body Lift Installation: 1st gen 4Runner vs 3rd gen 4Runner
  22. Defender (ORU) roof rack
  23. help with coil
  24. Cap fit/bed size?
  25. o2 senor..which one?
  26. Driveshaft hits gas tank skid plate at full stuft.
  27. removing clinometer
  28. Truck v. SUV, manual v. auto etc
  29. Mixing Advance Auto Univeral Coolant with Toyota Red?
  30. looking for a 2000-2002 4r 4x4 5sp
  31. Alignment specs?
  32. Where to buy ARB lockers and gears
  33. Safari Roofs
  34. my soon to be new truck PIC'S!!!
  35. Another question, cleaning pistons!
  36. What oil?
  37. Need Help!! My 4runner vibrates.
  38. Denver Area Yota Tech
  39. Chicago Waterpump Help
  40. Brake linings separating
  41. LSD fluid question, again . . .
  42. 2.7 vs 3.4? Manual vs. Auto?
  43. Anyone going to do the 5.7 L i-Force swap?
  44. objections to using a hitch mounted tire carrier?
  45. Brass union fitting for rear diff?
  46. MK1 MR2 Sunroof glass
  47. How to know what size pistons?
  48. OME N86, 2nd Gen or 3rd Gen?
  49. Plans to lock my truck
  50. Toyota Avalon - locate manifold absolute pressure sensor.
  51. Auto parts warehouse (buying parts)
  52. Look What I Found!!!!
  53. ARB Sahara Bar Questions.
  54. Rear diff fluid question
  55. Starting...
  56. Looking to find a used FJ80 or LX450
  57. gots me a ding
  58. does toyota use any 32mm bolt heads?
  59. aftermarket parts opinions
  60. Can someone near San Francisco look at a 4Runner for me? 3rd gen
  61. Engine Swap
  62. Leaking Windshield
  63. Synthetic Transmission fluid
  64. tire size
  65. Body Lifts bearing the load
  66. Getting rid of dog smell?
  67. 4 Roc?????
  68. The end of an era... Griots carrying a different random orbital unit...
  69. exaust tubing
  70. where to buy indak light switches?
  71. Steel Wheels
  72. Exhaust Jack ARB Bushranger X-Jack
  73. cam sprocket help!
  74. what grade fuel do you use?
  75. Aisin hub help
  76. Gear shift alllitle loose in drive....HELP!!!!
  77. Extended studs, where to buy??
  78. Flowmaster Super 40
  79. Another Tire size question...
  80. Cutting through Daystar spacers?
  81. A Little Help: Bearings Bad Maybe?
  82. Anyone bought a 22RE from Sunwest Automotive
  83. Wipers gone nuts........
  84. Any deals on shocks going on right now?
  85. Trailer harness ?
  86. *IF* I was going to sell....
  87. Solid axle cv joint/birfield rebuild-how to with pics
  88. Wheels painted pewter (pics inside) *56k it will be painful
  89. Throttle Body Spacers?
  90. Synthetic to Dino Again
  91. Aftermarket sunroof
  92. How to check engine compression?
  93. Lift Jack
  94. Simple oil change questions
  95. 50 more hp for FREE - it works
  96. Tundra Spindles
  97. Tire recomendations
  98. Diff Breather chances of water...
  99. What do you think is the best route to go for an alt?
  100. My Overdrive Light Is Blinking...?...
  101. How do I remove paint from bumper and tail light?
  102. rebuilt or used 22re
  103. Which way is up? copper cylinder Head Shim!
  104. Increase fuel mileage
  105. Chilton repair manual verses their CD
  106. 87 & 88 4 Runners ,which one to keep ?
  107. remove the ignition key cylinder? (pics inside)
  108. Is PORC still in business??
  109. tjm replacement bulbs
  110. Replacing top of dash
  111. Kar King Motors ???
  112. Need Help with SuperCharger Install (One Question!!)
  113. Put ToyBoxFab's 3VZE intake on.
  114. Innovision blades
  115. Hesitation accelerating/Fuel Injector Cleaning
  116. Spark Plugs Seized....advice?
  117. Painting wheels pewter
  118. Simple Hub question
  119. Exporting a 4runner from the U.S.
  120. I'm getting a second Yota!
  121. car dies after idle
  122. 2nd gen Vs 3rd gen: Which is better off road?
  123. I have a kink in the clutch hard line... is it okay?
  124. Cross Drilled Rotors
  125. Straight axle yota WTB
  126. Buying Parts Online
  127. When and when not to use the dealership?
  128. Getting my truck painted...
  129. Paint my leaf springs?
  130. Paper filter eaten away
  131. looking for an honest frame/body shop in reno/sparks
  132. How much Tire i got left?(pics inside)
  133. Getting GUM off leather..... Any Ideas?
  134. Got a S/C with piggyback? Wanna try something?
  135. Is there a good exhaust sealant
  136. Nology spark plug wires
  137. Which tire?
  138. Got to test the BFGs and watched a new Taco in action
  139. FINALLY took some pics... clean 93 !!!
  140. no cupholders?
  141. York air compressor
  142. Seat sagging and worn out padding
  143. Stupid truck accessories
  144. Rockcrawlers
  145. Installing sunroof and cut WAAY to big of hole! What now????!
  146. Setting a Gap on theDenso IK22 Spark Plug
  147. The Turbanator
  148. 22re head work..help
  149. 22re compression tests
  150. OK to only lock one hub? What say you?
  151. My 4Runner was stolen...
  152. My 4Runner & my brothers Tacoma are completely totaled...
  153. Best Clutch Pedal Height for Off-Roading
  154. FZJ-80 wheels arrive monday!!
  155. Cheap Hi Lift!
  156. PG Power Brute Differential
  157. Power Antenna Install?
  158. Lake George in ny -- trails?
  159. Snow plow
  160. Shock revalving
  161. My babies now have matching shoes!
  162. what's the best tool for this small job
  163. Rear axle bearing.. To replace or not?
  164. leaking valve stem
  165. Which option is best, engine swap, new toyota, or buy domestic?
  166. share your latest wheeling scar
  167. New tires = you gotta test them out right?
  168. Some toys (and a suzuki) video
  169. removing elocker connector-help!
  170. Build-Up update! Lift, tires, wheels, removed running boards, etc. Lots of pics!
  171. What to carry while 'wheeling
  172. Cleaning the Wood Grain
  173. Headlight Aiming
  174. Vibrations
  175. A Series of Events
  176. TrekMasters are on...First Impression....
  177. where can i get stock rims?
  178. Fixing Bad Paint Touch Up Job
  179. Lumbar
  180. Cab smells like oil??
  181. How many of you broken your Birfields?
  182. flopping the hitch
  183. My Tacoma got hot...
  184. Seafoam in the gas tank only - benefits/thoughts?
  185. Who Makes The 16x8 TRD Ivan Stewart Wheels?
  186. Mobil1 SuperSyn Extended Performance...Would you go 10k+ between oil changes?
  187. Ignition tumbler problem?
  188. What is the diff? W 56, R150, 151
  189. Is it ok to mix brands of Transmission fluid?
  190. painting aluminum rims black
  191. Binding brakes on Hilux
  192. L.A. area shop to install ARB?
  193. Mojave or Chamber Teflon
  194. Truck doesn't want to start after filling up....Ideas?
  195. Timing Belt & Water Pump Change
  196. 4runner Lift Vibration
  197. Should something ding when I leave my lights on?
  198. Need advice on used toyota purchase
  199. Finally added my driving lights
  200. Help identify this bumper
  201. Storing recovery gear
  202. Seattle Area body shops??
  203. Creaky body mounts
  204. 22RE rear main seal
  205. E-bay Find - 3rd Gen Hilux Surf Emblems cheap
  206. 3vz-e AFM is not too small - proven via math!
  207. Do you drive a Toyota with the 1GR-FE engine ??
  208. engine start up after rolling truck
  209. Heater Core Leak
  210. Tire Sizes
  211. Performance Friction Brake Pads = no more shaking
  212. is 11oz too much to add to tranny w/o draining first?
  213. Replaced the cat., now what??
  214. Body lift question
  215. JDM Inclinometer Adjustments.
  216. Air pressure warning light
  217. 2002 4Runner Question
  218. Rust removal
  219. More stuff for sale
  220. IFS Crossmember and D-rings
  221. is anyone here swapping these diesels in
  222. 4Runner Glove Box Problem
  223. Engine stumble-miss
  224. Passenger door tough to get open......
  225. Are you ready for 2006's gas prices
  226. Mudding Techniques???
  227. Zacatal Rack
  228. Burnt starter.. what else can be damaged?
  229. Mechanic question
  230. Holy smokes! literally!
  231. ARGH oil changer messed up on the filter
  232. Trade-in new tires from 06 4Runner for Revos?
  233. Toyota Carriers Suck!
  234. I just got my report from the mechanic
  235. Diesel FJ60 for sale on ebay - ending soon.
  236. Talk to me about your Mobil 1 experiences
  237. It's old. It's a solid axle. and it's MINE!!
  238. Coverking seat covers - anyone have any experience?
  239. BEWARE Eaton True Trac - bolts fall out
  240. Favorite tire for on and off road???
  241. Lots of Stuff for Sale...
  242. e-brake problem
  243. 295/75/16's are now planned - Wheelers Steel or Alum?
  244. Tip for those wanting 2.7L header
  245. E-Brake Cable break
  246. Nasty "Smokey" Smell...
  247. rotor broke like a dish
  248. Changing to synthetic oil?
  249. First real offroading trip...
  250. pix of rigs with sas and rancho 44044s
