Rear diff fluid question
Old Feb 13, 2006 | 08:32 AM
Ben03's Avatar
. . . lets say I have two bottles/litres of 80W-90 and one 75W-90, would it hurt anything to mix one 75W with the two 80W? I'm hoping not. Thanks guys.
Old Feb 13, 2006 | 08:53 AM
tc's Avatar
tc
I don't know the answer to your actual question, but it's a good question, cuz while the owner's manual lists the capacity as 2.3 qts, took the better part of 3 bottles to do mine...(I used Redline Heavy Shockproof)
My guess is that since the hot viscosity is the same (90), it will be OK - but don't risk your diff on my meager knowledge!
Old Feb 13, 2006 | 12:03 PM
Flamedx4's Avatar
No problem.
Old Feb 13, 2006 | 12:50 PM
V_Runner's Avatar
Banned for stupidity
i guess it would not hurt it...i've been doing oil changes since i was 10... and i mixed a few here and there... i wouldn't use to it but it shouldn't hurt it...ohhh and my 3.0L takes about 5-6 bottles of oil... it's a beast...
Old Feb 13, 2006 | 03:43 PM
Flamedx4's Avatar
I buy axle/trans lube in gallon jugs and put it in with a pump.
Old Feb 13, 2006 | 08:34 PM
Bobakazi's Avatar
You will just end up with a 77W-90. No problem.
Old Feb 14, 2006 | 05:35 AM
Ben03's Avatar
Thanks guys, I was changing my fluid on my 04 Tundra/LSD and the manual calls for 3.1 L, but in reality it is only about 2.5L, so I only used .5L of the 75W-90. In the future/next 15,000 miles I will be sure to have 3 quarts or more of the 80W-90 for the rear-differential so I don't have to worry about it again.
Thanks again for the info.
Old Feb 14, 2006 | 10:14 AM
Nic's Avatar
Nic
I have always heard it was Ok to mix weights of the same brand, but can be bad to mix weights of two different brands. Just what I heard.
Old Feb 14, 2006 | 10:31 AM
Ben03's Avatar
Thanks again, I used Valvoline as I have used Castrol in the past since it says that it/both can be used in Limited Slip applications and I assume I don't need the friction modifier that I used one time because it says it is good for limited slip diff's.
Believe me, I'd go with synthetic but the Mobil 1 full-syn is about $9 compared with $4 for the regular stuff, I can't justify the cost/benefit ratio.
Old Feb 14, 2006 | 06:39 PM
tc's Avatar
tc
Redline synthetic is $7.50/qt at Summit Racing - a great deal IMHO.
Old Feb 15, 2006 | 06:32 AM
Ben03's Avatar
I would like to use/try all these oils however, when they are not on a shelf at the local AutoZone or Wal-Mart, and BTW, all Wal-Mart has is the Tech2000 oil which is no good for LSD's, then I have no choice but to use what they sell at the local place. Sure, I could order away for the stuff but I can't be bothered, guys are lucky that have all these places and selections of stuff for sale.
Old Feb 16, 2006 | 06:24 PM
fireteacher's Avatar
I recently learned how to use the rear diff dutton on my 99 limited and went to try it out..all it did was flash...so i went to the mall and found a pile of melting snow and tried to get a wheel to spin. once i suceded i pushed the button and it flashed again, went through all gears and neutral but it wouldnt "lock" and i had to go to 4low to move. any help?? i was in 4wheel at the time.
Old Feb 16, 2006 | 06:56 PM
marko3xl3's Avatar
Without a simple mod (look in the mods section of the forum), that's how your 4Runner will act, it will not let you use your locker unless you are in 4Low. It's a really easy mod, check it out.
Old Feb 17, 2006 | 06:17 AM
tc's Avatar
tc
Yep "grey wire" mod IIRC. Search on TTORA too - very common mod for TRD Tacomas.
Old Feb 17, 2006 | 07:09 PM
so i thought i hit all of them, of course the one i didnt try! thanks fellas, gonna try it tonight. what does ttora mean?
Old Feb 17, 2006 | 09:18 PM
marko3xl3's Avatar
Toyota Territory Off-Roaders Association (used to be Tacoma Territory Off-Roaders Association...recent change). But, make sure to stay on YT
Old Feb 18, 2006 | 05:45 PM
i have looked for this modification and cannot find it. please point it out to me
Old Feb 19, 2006 | 09:21 AM
tc's Avatar
tc
www.ttora.com - their forum uses the same software as this one, so everything works similarly. I had better luck searching "grey" than "gray".
Foun this link - hope it helps:
http://www.customtacos.com/tech/inde...x_v2&id=10&c=3
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
Rkellerman
Jul 12, 2015 08:42 AM
Poncho0206
Jul 10, 2015 06:21 PM
87turboPA
Jul 9, 2015 05:58 AM
